White Peak Advice
[Closed] White Peak Advice
7 Users
So, me and a friend are planning to ride somewhere in the south peaks on Sunday. I have a copy of the VP book but I’m looking for some advice on a route, from said book, probably the Epics section, which will be riding ok and isn’t overly technical.
Suggestions please 😀
Posted : 13/11/2012 1:56 pm
millers dale circuit is good and not too wet
Posted : 13/11/2012 2:24 pm
There isn't a millers dale circuit in my book, it's not also known as the Cheedale Wye Valley Route by any chance?
Posted : 13/11/2012 2:40 pm
Dark is always better than White at this time of year! Grit is grippier than limestone - especially when wet.
But... As I've not go the book to hand. This route on my site might suit? [url= http://www.mountainbikerides.co.uk/routes/1-the-peak-district/12-eyam-a-bakewell.html ]http://www.mountainbikerides.co.uk/routes/1-the-peak-district/12-eyam-a-bakewell.html[/url]
Posted : 13/11/2012 3:16 pm
Yeah the white peak isn't too good this time of year, most of the legal stuff is pretty boggy. The trails around Northwood and Copy wood (near Rowsley) usually aren't too bad (probably some kind of '5 dales' route in the book or something?). However, I would cut out the Manners Woods part of this route - horrendous this time of year.
Mad Pierre's route above is pretty good, but I'd detour up past the Riley Graves between points 1 and 2, otherwise you are missing a nice piece of downhill.
Posted : 13/11/2012 3:40 pm
Yeah we usually do that but as the best DH option of the two past the graves is "cheeky" I didn't include it in the route!
Posted : 13/11/2012 3:43 pm
Theres another nice bit of cheeky trail just above there. Check out Hollow Brook... Wee bit slippery though.
Posted : 13/11/2012 3:47 pm
Hollow Brook? Better than the re-surfaced descent on the route? Will have to have a look next time I'm there? Not done it for ages.
This way into the back of Eyam is very short but fun: [url= http://mountainbikerides.co.uk/photos/local-rides/the-peak-district/bakewell-robbos-50th/bakewell39-3002.html ]http://mountainbikerides.co.uk/photos/local-rides/the-peak-district/bakewell-robbos-50th/bakewell39-3002.html[/url]
Looks flat in the phot but is nice and steep in reality.
Posted : 13/11/2012 3:58 pm
Hollow brook spits you out in Eyam... [url= http://www.streetmap.co.uk/map.srf?X=422335&Y=376809&A=Y&Z=115 ]clicky[/url]
I'm assuming your 'steep' trail is the dotted line to the west of this? Have looked down that hillside from the road but not ridden it...
Posted : 13/11/2012 4:37 pm
I appreciate that the dark peak is better in the winter, and probably better overall, but my friend doesn't want to go that far north and assume the white peak is less technical!
I'll have a look at the Eyam route, thanks for that Mad Pierre. Your sites very good, I'm actually pretty local to you and used to play football for Asfordby!
Posted : 13/11/2012 5:53 pm
 nbt
[quote=fathomer ]I appreciate that the dark peak is better in the winter, and probably better overall, but my friend doesn't want to go that far north and assume the white peak is less technical!
not sure it'll be less technical at the moment, I'd much rather have a grippy surface than be sliding left right and centre
Posted : 13/11/2012 5:59 pm
@fathomer - I rode there a month ago for the first time, the muddiest mudfest I've ever experienced - appalling. For comparison the Dark Peak has some of my favourite riding in the UK.
We did a guide book ride which was 50% roads (which were the best part of the ride) starting/ending in Birchover and round via Youlgreave - the real commedy stuff was in Gratton Dale
Posted : 13/11/2012 6:15 pm
not a bad ride even in the wet, can change to add in some of the routes already mentioned
Posted : 13/11/2012 8:24 pm
benman I'm assuming your 'steep' trail is the dotted line to the west of this? Have looked down that hillside from the road but not ridden it...
Yeah. Roughly there.
fathomer - Member
Small world and all that. I grew up in Asfordby!
Posted : 14/11/2012 8:36 am
