[Closed] ......................which SS rear hub ....?
16 Users
 jeb
Hello
Need a hub for my commuter bike, i would like it to be one of those where you screw on a freewheel.
-must be easy to maintain! -if possible only to bearings in the hub......
i found this so far...
https://www.bike-mailorder.com/bike-parts/hubs/15625.html
Posted : 11/01/2016 5:10 pm
What OLN?
120mm easy to find. 130 and 135mm trickier.
Posted : 11/01/2016 5:12 pm
[url= http://www.bricklanebikes.co.uk/Phil-Wood?pagenumber=2 ]Phil Wood[/url]
 JoB
assuming it's an MTB a normal MTB rear hub with a freehub and SS kit will be easier to maintain than a screw-on freehweel, unless you spend ££ on something like a White Industries freewheel
Posted : 11/01/2016 5:18 pm
What JoB said,
Unless you go with something like the WI freewheel then IME the bearings in screw on freewheels die long before the sprockets are worn.
And I've not seen any mid range 135mm screw on hubs for a while. DMR used to sell a catalogue one, as did On-One, but neither's on their sites anymore. That Halo one is 48h and 120mm OLN, which is an odd settup by anyones standards. Planet-X do some more normal spoke counts.
So, just pick a hub that suits your budget and fit a SS kit to that with a nice wide based sprocket.
Posted : 11/01/2016 5:25 pm
I think the DMR revolver may be what you are after, I have no idea if they still make them tho.
Posted : 11/01/2016 6:27 pm
As the hub you have linked to is a 120mm track hub then that is what you will need. I have used Halo hubs and found them pretty good. I also used a WI freewheel which lasted two years and had to replace due to worn teeth rather than any issues with the bearing so money well spent.
Posted : 11/01/2016 7:04 pm
Surly make a good range of sizes and styles too. I have a pair of them which I'd let go for the right price 135mm rear with one fixie and one freewheel thread.
Posted : 11/01/2016 7:19 pm
Just buy a wheel from single speed components, very good for my commuter
Posted : 11/01/2016 7:23 pm
I have a Brick Lane bikes freewheel that is really good and easily matches the white industries on performance and life.
Size is the key issue, for 135mm (MTB) A deore hub with SS kit is pretty good bombproof buy. (unless you can find a DMR or Surly)
Any less 120-130 any track hub with a freewheel thread and sealed bearings. The bearings are usually very easy to get hold of when they die.
IF you want real maintenance free go fixed.
Posted : 11/01/2016 7:39 pm
[url= http://www.charliethebikemonger.com/hubs-171-c.asp ]lots at charlies[/url] actually not as many as i remember and mostly out of stock. 🙁
Posted : 11/01/2016 7:48 pm
 jeb
-OH -forgot to say, the bike is a specialized Langster singlespeed frame....... it has quick-release on the rear, it is easy to use, but should i rather go with bolts ???
-and to be honest i dont know the spacing on the rear........... but right now there sits a singlespeed`ed XT rear wheel with quickreleasres .... 🙂
Posted : 11/01/2016 9:20 pm
Surly hubs would be a good place to start. Screw on freewheels are fine. About 3000 miles on my SS commuter and the freewheel is going strong.
Posted : 11/01/2016 9:40 pm
 Del
langster is 120 OLD, at least mine is. a ruler will confirm 😉
Posted : 11/01/2016 10:03 pm
Miche Primato low flange track hub. I've commuted on mine for three years. I run mine fixed and the hub is single sided, so none of that flip flop nonsense. Built up with Open Pros.
I picked low flange because I didn't want it to look like a track bike on the road.
Posted : 11/01/2016 10:36 pm
Having not to long ago bought a DMR single speed hub.
Id do what JoB said, if you've got a wheel to convert.
Posted : 11/01/2016 10:37 pm
 jeb
-found this surly rear disc hub :
http://surlybikes.com/parts/wheels/hubs_v1
REAR DISC, 135mm (MTB SPACING)
Black 32h 135mm O.L.D. Freewheel
....i hope the 135mm will fit my specialize langster frame!
-seems nice you can adjust the bearings...
Posted : 12/01/2016 8:48 am
It won't. Langster has 120 mm spacing. You won't be able to squeeze an mtb hub in, and unlike a steel frame, you can't cold set the spacing.
You want a track hub with 120 mm spacing.
Posted : 12/01/2016 8:59 am
 jeb
Thanks!
Posted : 12/01/2016 9:58 am
And unless you can build wheels, I'd buy a wheel as a shop will charge you £25 to build it, £30 for the spokes, and RRP for the rim etc it soon adds up.
www.singlespeedcomponents.co.uk have rear wheels that'll fit starting at £55 which will get you moving again.
Posted : 12/01/2016 10:06 am
£10 at Planet X/On-One for a 120mm track hub. These'll take a screw on free wheel.
[url= http://www.planetx.co.uk/i/q/HUOOLF/on-one-large-flangetrack-hub ]120mm Track Hub[/url]
Posted : 12/01/2016 10:12 am
