Which spoke length!...
[Closed] Which spoke length!?
3 Users
Had a spoke go on my 2016 Cannondale CAADX. Removed it and binned it. I would like to replace this spoke. I’m having trouble ascertaining which spoke length I need. Tried to measure one in situ and can’t be precise enough to work out which I need. Any pointers!? Thanks!
Posted : 06/06/2020 11:22 am
You might have to remove a second one and measure it.
Posted : 06/06/2020 11:32 am
Remove one from the same side that is diametrically opposite on the rim (to avoid too much tension fluctuation) and measure that.
When you put it back in (and the new one) make sure that it is interlaced (weaved over / under the other spokes) the same as the ones around it.
Posted : 06/06/2020 11:35 am
