which size single r...
[Closed] which size single ring? gearing up a 1 x 10 29er
9 Users
recently bought a Genesis Fortitude and finding the riding I do is to fast for the top end. I'm mainly doing canals, bit of roads etc and could do with throwing a bigger chainring on. it has 32 at the moment.
Should I go 34 or 36? it also has a chain guide, would that cope with it, or is it a case of sliding that further up the down tube to compensate?
Posted : 13/07/2012 7:36 am
If you really feel the current set is too low I doubt 34's worth the bother - only 6% or so uplift in ratios
(guide should be movable but I dunno whether yours is. Have a look; it won't need to move far)
Posted : 13/07/2012 7:41 am
I'm finding a 36T pretty good but that's for xc racing
Posted : 13/07/2012 9:37 am
Make a decision after you stop going on canal tow paths and you ride it up a hill. 😉
Posted : 13/07/2012 10:01 am
36 on a 29er with an 11-up cassette gives you a fairly reasonable top gear. Depends how much you want to compromise?
Posted : 13/07/2012 10:09 am
My Swifts 32-18 and that's good enough off-road (52"), I suggest you look at your route choices rather than gearing 😛
Posted : 13/07/2012 10:26 am
 mboy
A 32T is already the equivalent of a 35T on a 26" bike due to the 10% larger rolling radius of the wheels. If you stick a 36T on it, it will feel like a 40T ring on a 26" bike. That is to say, quite tall!
Depends if you're going to take the bike offroad properly though. If it's staying as a canal towpath and road pootler, then gear up by all means, if you're going offroad properly on it at all, I'd keep the 32T myself.
Posted : 13/07/2012 10:30 am
You've clearly bought the wrong bike Mick, i'd flog it cheap to someone in the club and buy one of the following:
Lapierre Zesty
Gary Fisher Rumblefish (but not a proper Gary Fisher like Kiwi's)
On One 456
Cube Stereo
etc
etc
Seriously, if you clear Belmont (going up) at the weekend THEN i'd start looking at swapping rings. I was on a 34t 1x10 set up last (but with the correct sized wheels) and whilst it was hard going i did it no dabs and didn't feel i needed another gear.
Welcome back btw 🙂
Posted : 13/07/2012 2:27 pm
33:18 with a Tazzy supplied wobble ring.
Spins out quickly on the road but its about perfect for Cannock.
Coupled to an 11-36 should cover anything.
[url= http://farm8.staticflickr.com/7056/6928674149_84b6988920_b.jp g" target="_blank">http://farm8.staticflickr.com/7056/6928674149_84b6988920_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/6928674149/ ]IMAG0335[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Posted : 13/07/2012 3:07 pm
36T on 29er to tall? Rode the Brecon Gap on it last week, and have ridden all around the Peak on it no probs 8) 11-36 at the back. Can get a bit tiring after 4hrs+ but otherwise just about bob on. It was chuffing hard work at Hopton Wood though, regretted not putting the double back on
Posted : 13/07/2012 4:01 pm
