Which singlespeed c...
[Closed] Which singlespeed cog for a Hope cheese-wheel?
11 Users
Looking to minimise freehub chewing on a new build.
Posted : 28/02/2012 10:18 pm
[url= http://www.on-one.co.uk/i/q/SKOOSSGA/on_one_groove_armada_single_speed_sprocket ]Groove Armada[/url]
Posted : 28/02/2012 10:21 pm
Surly has a nice wide base...
Posted : 28/02/2012 10:23 pm
I saw someone adapt an old sram cassette spider by removing all the old cogs and then spacing a single cog onto it. Don't know which cog they were using or whether it was a ss cog, suspect it night just have been a cog off the cassette. Looked good and certainly wouldn't dig in! Or you could buy a steel freehub body, think they are about £50 though
Posted : 28/02/2012 10:32 pm
Superstar wide base here.
Posted : 28/02/2012 10:35 pm
I have a Surly on my Hope freehub which has a 4mm base and doesn't seem to be causing any damage. Very nice if don't object to spending £20 on a cog. Gusset and Halo both do one with a 7mm base but they're both 1/8" specific whereas the Surly works with a 3/32" which allows you to use 8 or 9 spd chain.
Posted : 28/02/2012 10:39 pm
The Superstar ones are nice & wide. Bit wider than a King if I recall. They are pretty soft though. Also the wide base is all on one side, so not sure if that might have an impact, compared to a King etc. Surly are meaty old beasts, but pretty heavy though. You could swap the chainline every month or so to even it out.
Posted : 28/02/2012 11:15 pm
Shimano...hub 😛
Posted : 28/02/2012 11:16 pm
I have a wide base Chris King 16T, unused going spare, if interested?
Posted : 28/02/2012 11:17 pm
 IanW
Trouble with singlespeed is that you do wear out the cogs quicker, recently Ive had gusset, surly and on one groove armada, all much the same. Groove armada at a pinch would get my vote.
Posted : 28/02/2012 11:19 pm
 Haze
Had Surly's in the past, stood up pretty well and never chewed my Pro 2.
Trying out a King stainless at the moment...
Posted : 28/02/2012 11:26 pm
I'm using a niner cogalicious my missus bought me for my birthday. Has been on about 8 months, and seems fine so far.
Posted : 28/02/2012 11:30 pm
