Got a lot of play which seems to be mainly at the upper shock bushing. I'm a bit of a numpty though and I can't work out exactly which bits I need from TFTuned.
I currently have a Fox DHX5 coil shock on there, if it makes a difference. When I fitted it I just used the mounting stuff from the RP2 that I took off.
I think it's this - Heavy-Duty Mount Kit, 12.7mm, M8x22. But I'm not sure. Do I need anything else? Help!
http://www.tftunedshox.com/Miscellaneous/Mount-Kits-and-Bushings/Mount-Kits-127mm
Thanks. 🙂
yes they are the correct ones on both ends.
edit: nothing else needed they will come with a bush
Thanks 🙂
