which shimano brake...
[Closed] which shimano brake adapters do I need IS/post ?
4 Users
hi, just pushing the button on some deore brakes.
fork is a RS tora 302 solo air and frame is a cotic soul?
which adapters do I need? all this post to IS is a little confusing.
thanks
Posted : 03/01/2015 1:57 pm
anyone? thanks
Posted : 03/01/2015 2:21 pm
Threaded holes PM
Plain holes IS
It will probably be PM front IS rear.
Posted : 03/01/2015 2:36 pm
I bought deore brakes from Merlin.
It depends on your rotor size.
For front Suspension fork and a rotor of 160mm you can direct mount the caliper, no adaptor needed. For 180 rotors or higher you need a post to post mount adaptor 5.99 quid from CRC.
For the rear I used post to IS on my cotic solaris, again rotor size specific.
Does this help at all?
Matt
Posted : 03/01/2015 7:30 pm
The frame is definitely IS mount and I have a strong suspicion that a Tora 302 is IS mount as well. On the fork, IS mounts are 2 plain holes that go sideways across the fork, post mount are 2 threaded holes where the bolts fit from the rear.
Posted : 03/01/2015 7:35 pm
googled tora 302, davewalsh is correct, they are IS mount by the looks of it.
Posted : 03/01/2015 7:54 pm
