Which Rohloff?
[Closed] Which Rohloff?
5 Users
I've got a Surly Troll and the dropout (piccie from the web, with a Rohloff fitted) looks like this:
[img] ?w=450&h=299[/img]
So which Rohloff do I need? I'm guessing TS rather than CC but is it OEM or OEM2?
Posted : 23/02/2014 11:15 am
The [url= http://surlybikes.com/bikes/troll/bike_info ]Surly website[/url] says OEM2 but it looks like the Rohlof in the picture is OEM. Hmmmm....
Posted : 23/02/2014 11:23 am
I'd go with OEM2, I think. There's significantly less meat on the lower half of that track end than a Rohloff-specific dropout. It would [i]probably[/i] take an OEM plate without distortion, but it would be a risk. It would also limit the chain adjustment available before the tab drops out the track end.
You'll need a Monkey Bone to fit an OEM2 plate with a disc brake, of course....
Oh! Hold on! Looking at that photo again, I reckon that's a OEM2 mounting with the plate engaging the bottom bolt. The dark patch in the dropout is just shadow, and only the two upper bolts are holding the calliper. A cunning way of avoiding the Monkey Bone.
Posted : 23/02/2014 4:33 pm
Yup, on that dropout it's an OEM2 onto the bottom slot.
Posted : 23/02/2014 4:49 pm
And ts is solid axle, cc is qr. personal pref, either will be fine so long as you use a chain tug with a qr version.
Posted : 23/02/2014 5:12 pm
Yup, officially you're meant to run solid axle on track dropouts, but as long as you've got a decent chain tug then QR is fine.
(Should I mention that I still seem to be on the premier club discount list, should you be interested in 10% off?)
Posted : 23/02/2014 5:17 pm
Nice one! Thanks for that 🙂
Posted : 23/02/2014 6:50 pm
I've used a Rohloff with horizontal dropouts and a QR.
Some Qrs wouldn't grip, no matter how tight I did them up, some worked OK.
I can't remember now which were the good ones, but going by [url= http://sheldonbrown.com/skewers.html ]Sheldon Brown's advice[/url], if you use one with an enclosed cam and steel teeth, I reckon you'll be OK without a chain tug.
Posted : 23/02/2014 6:57 pm
Many, many years ago, when there was the worry about disc brakes causing QR wheels to pop out, I did some proper scientific testing of lots of quick releases.
Best was the old-fashioned Shimano ones, with the enclosed cam and steel body. Worst were various types with open cams, alloy levers, and plastic cam spacers - some didn't even past-centre lock, they were just relying on cam friction to hold them closed.
Posted : 23/02/2014 6:59 pm
