Which replacement r...
[Closed] Which replacement rear shock bushings?
8 Users
 kevj
There is a small amount of play in the rear triangle of a bike I've recently bought and I've traced it to the shock bushings. Currently looking at TF Tuned offerings and I'm also interested in the needle bearing option by Betd. Looking for real world experience of both please.
Posted : 05/06/2017 6:27 pm
 kevj
Does anyone have experience of offset bushings as a manufacturer? I'm not after offset as I'm have with the geometry of the bike, just want a decent set of replacements.
[url= https://www.offsetbushings.com ]Offset Bushings[/url]
Posted : 06/06/2017 10:09 am
If there's a slight click of play as you lift the saddle it's likely to be the DU bushing rather than the hardware (what you just posted a link to).
Posted : 06/06/2017 10:21 am
Standard DU bushing code for Fox shocks (and many other) is 08DU08.
They are available from bearing factors or online and they'll cost pennies. Change these first (as chakaping says).
Needle roller bearings are a step-up in longevity, in my experience at least. (They're standard fit on Litevilles)
Posted : 06/06/2017 10:34 am
I'm a fan of the polymer bushes over standard DU.
Ive always used the TF replacements except for the polymer bushes, which I got from Katec RIP in a bundle of 10 pairs plus tool...
Posted : 06/06/2017 10:45 am
 kevj
There is play in the bushing, but there is also lateral movement in the shock at both top and bottom ends of the shock. It slides ever so slightly along the shaft.
Posted : 06/06/2017 10:50 am
Been looking at these today for my bike: http://www.enduroforkseals.com/id275.html
Must be a better solution on standard bushings?
Comparison:
I would assume less chance of the potentail rocker arm wear that could occur
Posted : 06/06/2017 12:41 pm
I have a shock set up with needle bearings. it PERMANENTLY has play in it, as has every other one i have seen. they are a great idea and do smooth out the suspension action if you have loads of rotation from linkage to shock. But, they are not play free.
I stick to Normal bushes now.
Posted : 06/06/2017 12:50 pm
The upper shock mount on my 2009 Anthem developed play after about a year. Replaced it with a BETD strong bush and hula hoop and it's been fine ever since.
Posted : 06/06/2017 1:38 pm
The BETD pale yellow polymer ones last longer than the metal/teflon DU bushings in my experience, probably the same goes for the similar (but different coloured) ones you can get elsewhere.
@Dango that wear would indicate you are not tightening up your bolt enough (or maybe the design doesn't allow this). Now its worn, it would be even difficulter to get it tight enough. You might try a slightly longer bush reducer, BETD do them, or get some slim shim washers for the ends. I have an old bike like that and it needs 1/10 mm washer for me to be able to tighten the bolt enough.
Posted : 06/06/2017 1:53 pm
Cheers, thats not my bike though thankfully, its from from the RWC site advertising the needle bearing solution that I'm not going to bother with after all 🙂
Posted : 06/06/2017 2:52 pm
