Questions for the collected wisdom:
I'm in a position to get a set of Michelins for the 27.5 "Enduro" bike but I don't really know the range so can't pick the right ones. Could you help?
I like soft tacky fronts and fairly fast rears. Currently running Minions F&R. Front is a 2.5WT 3C MAX GRIP EXO, rear is a 2.3 3C MAX TRAIL Exo (I Think).
Given I want a similarly draggy (or not) and similar strength/weight setup, which Michelins should I go for? I'm thinking:
Front - Michelin Wild Enduro Magi-X Tyre Front 27.5 x 2.4"
Rear - Michelin Force AM² Tyre 27.5 x 2.40"
Does that sound right or is there a better combination?
Any experience welcomed.
Oh and to complicate things I'd like them to both have the same graphics - I'm particular like that.
G
The graphics won't match on your chosen combo. You need the raceline wild enduro to get the yellow/blue hotpatch. But that is a much heavier tyre and would be a mis-match potentially.
Probably better to get a gumx3d wild enduro rear to go with the wild enduro front.
Then there is the compound on the front to think about. The magi-x is meant to be harder, but grip better at full-on race speeds for proper rippers....or something like that. Gumx 3d for punters as it's softer at lower speeds.
TLDR - Get Gum-X 3d wild enduro front and Gum-X 3d wild enduro rear. Or the Magi-x front if you are fast.
Quite happy with my wild enduros (f + r). They are on all year round. As above just choose the tacky-ness you want in a tyre and go from there
Old biffer here and I prefer the Magi-X on the front, slower rebound suits me.
Magic Mary front, Wild Enduro Front on the rear. You heard it here first! Admittedly a bit toothy for Summer but grips like shit to shovel.
chestercopperpot
Tyres from different manufacturers front and back? Never - I'm not a pervert! ;o)
Thanks for the info all.
G
Tyres from different manufacturers front and back? Never – I’m not a pervert! ;o)
Surprised I've not been burnt alive inside a wicker man yet.
Wild Enduro is really excellent but do be aware it's seriously, seriously slow. Slower than a shorty 2.5 never mind a minion.
Pirelli S enduro front. R enduro rear.
Lighter, faster, cheaper.
I'd go with Gum-X rather than Magi-X, unless you're super fast. Also the Wild Enduro rear I had wore down faster than any other tyre I've ever used, and I could never get the front to hold air for long. Good tyres, but come with their own issues.
Magi-X2 WE front is really good. Though I warrantied my last one as the knobs started cracking after 2 months. Replaced it with a soft Mary, which has lasted way longer and is just as good as a Gum-X2 WE.
Ran a Force AM2 in the back and that was great in the dry to herodirt conditions but lacked in the mud. Replaced that with a soft Big Betty (and also brand-matching🙄)
I need to replace my wild enduro..... 60 quid!!! 60 quid!!!!
Hot S.
i may be behind the times.
