As per the title. A search on eBay throws up 241,243,262 & 270.
Which one for regular bike use eg rotor bolts etc??
EDIT. and 572
*confused*
242 is the default option- it's also the one you'll find in most shops. But tbh I don't use any of them on the bike except when dealing with badly sized parts or annoyingly loose things (quick release seatpost bolts frinstance)
I use 222 on most things. Works on small fasteners but can be undone with handtool without rounding things.
The correct one for your application 🙂
http://www.loctite.co.uk/cps/rde/xchg/henkel_uke/hs.xsl/fullproduct-list-loctite-4995.htm
