Which loctite for c...
[Closed] Which loctite for crank arms?
10 Users
Laddos crank arm keeps coming loose and literally falling off. Is it just a Google for loctite blue? It needs a new bb soon so I don't want anything too weldy! TIA
Posted : 13/09/2018 7:45 pm
Go for red, it's more for items that aren't often removed. There is a version for taking up the slack in bearings (yellow) which might do if the red doesn't work.
Posted : 13/09/2018 7:51 pm
You probably need new cranks.
If the spline or taper is damaged no amount of loctite will hold it on .
Posted : 13/09/2018 8:26 pm
What Al said
Posted : 13/09/2018 8:33 pm
yeah, the force even a kid will put through a crank would defeat anything other than actual "weldy", I reckon
When I did mine once (the old octalink ones) I wondered about putting some sort of bolt right through the middle of the crank axle, like those headset tensioners - figured maybe with a nice nyloc bolt on that might just hold it.  DIdn't fancy mashing my ankle on the bolthead though so I got rid and replaced.  I suppose if you were good you could make a countersunk version but then if I'd been that good I'd prob not have ****ed my crank
Posted : 13/09/2018 9:00 pm
407?
Posted : 13/09/2018 9:15 pm
What cynic al said.
Posted : 13/09/2018 9:19 pm
Mmm this is an old octal8nk one. What tools do I need to butcher it out?
Posted : 14/09/2018 4:48 am
You just need a standard B.B. tool. New octalink B.B. can be got for less than a tenner
Posted : 14/09/2018 6:50 am
chances are that it's the crank rather than the BB
Posted : 14/09/2018 7:04 am
It'll definitely be the crank not the axle.
Posted : 14/09/2018 9:53 am
aluminium crank vs heat treated hardened steel BB
only gonna be one winner
Posted : 14/09/2018 9:56 am
How tight are you doing up the bolts?
I've never used threadlock, run octalink a lot and never had a bolt come loose.
Posted : 14/09/2018 10:34 am
issue being if its come loose even once and you have kept riding it till it falls off
it aint going to stay tight going forward.
Posted : 14/09/2018 10:52 am
