To fix a loose headset into a headtube? Headtube is a little big and I dont want to shim it.
Or is there another adhesive people recommend?
660 is a good gap filler
*EDIT - I promise I didn't just read that from above, just what I've used at work*
Cheers.
Motivforz - yeah right we believe you 😉
Without me starting another thread (Hope the OP dont mind?)
What loctite would i need for frame bearing pivot (Dropout) bolts ?
be careful with things like 638 and 648 - ideal for setting liners into cyclinder blocks but are designed for items that are not expected to come apart...
for the DIY/home uers then (641) is ideal, the easy to get 'stud bearing fit' #270 which is sold in little tubes in halford etc is not so good as it not ideal for bigger gaps... but if your stuck worth a try..
as with all for instructions and leave assembled parts to properly cure before usinge tc
