which gear cable ki...
[Closed] which gear cable kit?
7 Users
Any recommendations on gear cable kits.i want to replace the rear derailler inner and outer.xt 8000.
Ta
Posted : 07/09/2017 5:31 pm
I bought 2 of these for my bikes [url= https://www.tredz.co.uk/.Shimano-MTB-Gear-Cable-Set-With-Stainless-Steel-Inner-Wire_51239.htm ]https://www.tredz.co.uk/.Shimano-MTB-Gear-Cable-Set-With-Stainless-Steel-Inner-Wire_51239.htm[/url] enough to do both the dropper and rear gear. At the time with tredz £5 pop up code that was the cheapest. As ever shop about.
Posted : 07/09/2017 5:38 pm
Not the Wiggle Lifeline set. Shite.
Posted : 07/09/2017 5:55 pm
Just buy sp41 by the metre and some decent inners
Posted : 07/09/2017 5:57 pm
Its internally routed.does it make a difference?
Posted : 07/09/2017 7:33 pm
I've been buying the Uberbike stuff for a while and it's been great. Surprised no one ever seems to recommend it.
Posted : 07/09/2017 8:52 pm
Shimano cable and casing inc the genuine ends.
Often better value off the reel from a bike shop rather than generic kit which you don't use all of.
Shimano 11 speed sil tech inner cables are a bit costly but on most bikes I've found the sram pit stop ones work ok and are 1/4 of the price.
11 speed stuff does not like cheap cables
Edit avoid the first generation gold coated Shimano inner , the coating comes off and jams into everything
Posted : 07/09/2017 9:21 pm
I like the Transfil black snake stuff.
Very slick changing.
Posted : 07/09/2017 9:59 pm
