which drop bar leve...
[Closed] which drop bar levers to work with cable disc?
8 Users
 ton
fancying a drop bar set up on my disc trucker, so looking for some cheap levers or even sti units that work with cable discs.
any idea's greatly welcomed.
Posted : 04/02/2015 7:57 pm
If they are road BB7s then any STI unit should work. I've used 105 and Ultegra
Posted : 04/02/2015 8:00 pm
campag chorus works too
Posted : 04/02/2015 8:04 pm
If mtb disc brakes then Tektro RL520 will do the job nicely.
Posted : 04/02/2015 8:06 pm
 ton
think they are mountain bb7 does it make a differance
Posted : 04/02/2015 8:07 pm
It does make a difference Ton - designed for different cable pulls. They will need a lever designed for V-brakes such as the Tektro RL520.
If you want to run stis then you'll need road cable brakes.
Posted : 04/02/2015 8:10 pm
 ton
them tecktro ones look ideal......price suits my tight wallet.
nexy question, gripshift mounted on the barends? cables would look no worse than barend shifters.
Posted : 04/02/2015 8:12 pm
Think you may struggle with bar diameter. Pretty sure mtb bars have a narrower diameter at the end than road bars.
Posted : 04/02/2015 8:16 pm
Yep, different bar dia. Plus it would look gash.
Posted : 04/02/2015 8:26 pm
9speed?get some cheap bar end shifters, much nicerer.
Posted : 04/02/2015 8:29 pm
like this one:
[url= https://farm9.staticflickr.com/8536/8646361188_eaf0c55801_b.jp g" target="_blank">https://farm9.staticflickr.com/8536/8646361188_eaf0c55801_b.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/82598458@N05/8646361188/ ]Bristol 001[/url] by [url= https://www.flickr.com/people/82598458@N05/ ]jamesanderson2010[/url], on Flickr
Posted : 04/02/2015 8:32 pm
[url= http://www.todayscyclist.co.uk/product.aspx?X=ONHB052 ]Try a dropbar with mtb diameter.[/url]
I use them on my mtb. It allows the use of mtb levers.
They are a shallow drop, but you don't want a deep drop on mtbs - the idea is to have your hands at the same height as usual.
Comfortable for 120 mile rides in a day.
[url= https://farm4.staticflickr.com/3882/15023238888_4d99ea902d_b.jp g" target="_blank">https://farm4.staticflickr.com/3882/15023238888_4d99ea902d_b.jp g"/> [/img][/url]
Posted : 04/02/2015 9:56 pm
Oh dear nipper. Nervous breakdown in an anodising factory perchance? 🙂 That looks like a Gilles Berthoud thingumybob?
Posted : 04/02/2015 10:37 pm
Not mine. I quite liked when I saw it at Bristol apart from the twist shift thing.
Posted : 04/02/2015 10:45 pm
