Which DH crankset t...
[Closed] Which DH crankset to pick for Lapierre 727 frame
2 Users
Hi guys,bit of problem here as im trying to sort my rig build and i have a dillema what sort of crankset to buy.I have a Lapierre 727 DH Team Gravity Republic frame and it currently has shimano SM-BB71-41A installed,its apparently known as BB92 and diameter for crank spindle on this is 26mm.Now the confusing part,frame has a 109mm in width of BB so my logic says its for 109mm spindles with 26mm diameter,right?
I dont want to go for saint setup,was thinking more truvativ descendant and i got occasion to buy Truvativ DH 1.1 165mm crank lenght on BB30,but spindle is 15mm shorter then bracket so it wont fit.Can i just buy a spindle from truvativ? Any help would be much appreciated,thanks
Posted : 28/07/2019 6:17 pm
Something wrong there, Shimano BB92 is for 24mm standard shimano axle (that's what's in my Remedy). You can get different sizes for a 41mm press fit BB, frinstance I've had a Raceface 30mm in that bike, but that part number is for a 24mm
I believe 107mm BB shell + BB92 takes an 83mm crank. (because confusingly, the crank width, 73mm or 83mm or whatever, doesn't include the BB cups which on a traditional external BB, adds on about an inch). But you'd want to double check that.
If so, stick a saint 83mm in it.
Posted : 28/07/2019 7:00 pm
Hey,thanks for prompt respons.I've measured it again and yeah my bad,it is 24mm.So what sort of crankset you have on trek then?
Posted : 28/07/2019 7:07 pm
Ancient xtr but mine is a standard BB92 so it's narrower than yours. I've got a Saint in the dh bike though and can't see past it, they're ace
Posted : 28/07/2019 7:16 pm
