Which Crankset?
[Closed] Which Crankset?
7 Users
Going to leave the dark ages and bring my remaining bike in to the world of 1x.
It has a BB92 bottom bracket. The current Crankset is SRAM GXP. It's non boost.
Will any crankset with a 24mm spindle work?
My screw thread BB on the other bike is 73mm. are the cranksets for both the same width?
Sorry for the dumb questions.
Posted : 07/02/2019 1:56 pm
GXP c/set will fit BB92. You need a pressfit BB92 GXP BB
If you want to fit a different c/set then you'll need a different BB.
You don't say what the c/set is on the 'other' bike, so it could be Shimano or GXP...
If you can be a bit clearer on what c/set you want to fit to what frame, then we can answer.
Posted : 07/02/2019 2:16 pm
The crankset on the other bike is a Shimano XT M8000 fitted to a 73mm screwthread BB.
The bike for which I require a new crankset is an On-One Race29 (same as the Lurcher essentially).
Posted : 07/02/2019 3:13 pm
I'd probably stick to a 24mm BB with that BB so you get bearings that aren't unfeasibly small. Making that choice a while back I think it can down to Shimano slx/xt or race Face aeffect. The deciding factors were if.you could get a small enough chainring on the Shimano and cost. I could and the Shimano was cheaper, so that's what I have.
I think just about anything else was fair bit heavier.
Posted : 07/02/2019 4:14 pm
I have an Aeffect. Quite like it...I'll likely go for the same again. The Shimano ring seems to sufffer from a little bit of chainsuck!
Posted : 07/02/2019 5:35 pm
Affect are a bastard to remove... you need a 3 foot Allen key.. Shimano are easy...
Posted : 07/02/2019 5:52 pm
I'm not using the Shimano ring- works components oval comes highly recommended. Lasts for aaaaages. I can normally get a narrow wide fitted in ~march worn to the pint where it's dropping chains by August (two years on the trot I kept dropping chains at the Brighton big dog, that's how I know) but the current works one is going to be two years old in march. Admittedly, the entire drivetrain is utterly knackered but it's still hanging on to the chain
Posted : 07/02/2019 5:58 pm
Can you just fit a normal gxp crank? If so I’d look for a gxp sram nx eagle crank or a truvativ stylo / descendent gxp crank. All generally have direct mount chainrings hat retrain he chain really well. I honk I found my stylo gxp crank on eBay for £60 with a 32t alloy chainring in it (light - butnid prefer the steel ones as they last forever).
Posted : 07/02/2019 6:24 pm
I assume I can fit a normal GXP crank...as that is what's there at the moment. I just need a 1x version and then don't have to change the BB to a Shimano specific one.
Posted : 07/02/2019 6:26 pm
Not me selling - this could work? Buy a direct mount steel sram chainring for under £20 from somewhere like Tredz.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F303037113839
Or these - although you’d need to check boost / non boost
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F153092865432
Posted : 07/02/2019 6:52 pm
@Mccraque does you crank have a removable spider? Does it have 3 bolts holding it onto a splined interface or are the spider and crank arm one piece?
If it is removable then you can fit a DM ring or boost spider and ring... and just as an aside I have one of those going spare. PM me if interested.
Posted : 07/02/2019 9:30 pm
Thanks Joemmo - I’ll take a look but pretty sure it’s 1 piece with a 120bcd
Posted : 08/02/2019 7:40 am
The old answer for weight Vs cost was always slx
But raceface aeffect have now edged it
Posted : 08/02/2019 8:02 am
