Which Calliper adap...
[Closed] Which Calliper adapter
3 Users
I currently have a set of magura ronin front forks with IS mounts.
I have a 4 pot hope galloped mounted and a 185mm rotor.
I want to upgrade to a bigger rotor, can anyone advise what adaptor I can get to allow me to upgrade?
Thanks
Colin
Posted : 12/08/2011 1:16 pm
locoboy,
You need an IS-IS +20mm adapter to keep the same forks and calliper with a 20mm larger rotor.
Not sure what you mean by 'galloped mounted' so assumed it was possibly a PM-IS adapter which you retain.
Hope make them, as do several others.
Check CRC for prices and nice piccies.
PaulD
Posted : 12/08/2011 1:45 pm
Superstar also make adapters, and they're cheap as well (~£5). If you can work out what you want get it from them if they make it.
Posted : 12/08/2011 2:19 pm
Sorry, damn predictive text it should say caliper!
So IS to IS +20mm will take me up to a 205mm rotor?
Posted : 13/08/2011 6:15 am
