I am currently running a set of 2012 Lyrik RC forks on a Carbon nomad and for some reason just can’t seem to get them working right. They came with the bike when I bought it and have ridden them for some time even giving them a service and changing oils and seals.
I have done a search and there is not much in the forum that is up to date on what the best 160mm travel fork out there is at the moment and so wanted to ask.
I was thinking maybe the new Talas 160mm fork as I have found that the front end does wander a little when climbing and is much better when would down to 130mm.
I have had a set of 2009 talas forks which where fantastic and really enjoyed them but just thought I would ask as they are new to the market and so not much news on them.
Any other forks to think about?
In what way are they not working right? Do you have the correct spring for your weight? Have you read the set-up guide on the SRAM site?
Lyriks are awesome forks and should work for you.
55 rc3 ti 🙂
best forks ever. FACT 😉
Lyrics from further up the spec ladder? LOCO might be able to sell you a higher end damper which might work out cheepest?
Fitted some BOS Deveille a month ago and i'm thoroughly impressed with them
However, I understand that the STW crowd is somewhat divided on them......[i]awaiting sudden rush of abuse [/i] 🙄
Could check out the new SR Suntour Durolux RC2 TA forks. Adjustable from 160mm to 120mm via handlebar mounted lever.
Is there any problem other than that the front end seems a bit wandery? I reckon for most bikes now travel adjust isn't really necessary, a wee change to the bar/stem/saddle and a bit of body english sorts things.
Or are you really just hankering after a new fork? 😉
As above, Lyirks are (or have the potential to be) awesome.
What model/damper have you got and can you be specific about your problems?
My lyriks are great.
An after market Avalanche Lyrik damper cartridge would sort your forks out.
You have the basic rebound only fork so it would really help.
As mentioned I have the basic lyrik rs with motion control. So maybe an upgraded version may change things. it wanders only because the front end is to high but is great when dropped to 130mm. It's only up steep grany ring climbs that it wanders not normal trail riding.
Yes a new fork would be great but I am happy to give the lyrik's another shot with some changes. What I don't like is there is no small bumb compliance...what ever the hell that means. By that I mean that rooty or rocky trail riding sends judders up my arms and it takes quite some force (in my eyes too much) to depress the forks but once going they feel good.
At pace it's like riding a pogo stick up front. I am riding them at 20% sag which is hard to get wrong as they have the sag settings on the stantions. I have the right psi for my weight all geared up.
Try slowing the rebound setting right down- I had the same problem on my fox float 32s; going real slow on the rebound sorted it and it doesn't pack down on repeated hits at all.
FWIW, I bought a cheap pair of Solo R Lyriks, and fitted mission control rebound and compression dampers- only used it twice before changing the dampers - the fork was imo an utter pile of cack with the original setup. Either get rid of, or swap out the dampers for current mico dh ones- it's only a 30 minute or so job.
Same here - truly excellent fork but I suspect they need to be ridden hard to pay dividends. Go slows need not apply.
I'm on the Solo air RC2DH and the fork is very composed, patters nicely on the small bumps and tracks well through roots as well as soaking big bumps and drops.
Solo airs? Have you tried dropping the pressure a bit? This should help with the sensitivity.
I'm pretty sure the RC2DH dampers are a retro fit and could be worth exploring, much cheaper than a new fork.
Motion control was sh1t in Pike forks (a very overrated fork IMHO)... Upgrade to Mission control or Avalanche... I'd love to try the Avy.
If I sold the forks and added the cost of the avy mod I'm close to adding a few quid and getting some new forks.
Happy to spend cash on the forks but don't want to throw money away.
If I sold the forks and added the cost of the avy mod I'm close to adding a few quid and getting some new forks.Happy to spend cash on the forks but don't want to throw money away.
But it "could" be argued that an Avy upgraded fork is better than any standard new fork**
**I've no idea if this is factually correct but Avalanche stuff does get good reviews.
Two things really
The PSI on a fork is plucked from thin air, the other numbers from the arse of whoever is around. Never had one that was anywhere near right.
When you set sag are you sat on the bike or in the attack position (one requires a mate)
Try setting to 25% sag in attack position then go from there with rebound etc.
Best tip I had was to take a shock pump to a local trail with a bit of everything and ride laps till it was right.
I have a mission control damper from my broken(CSU) Lyriks I am selling. If interested I will send it to you to try out, if it does what you want buy it, if not send it back.Nothing to lose, but time and postage. email in profile if interested.
You've loads of stuff above to try, and better damper would probably pay dividends, but on your current set up, less air/smaller spring, and slower rebound sounds like a necessary set-up adjust..
PSI/Weight on forks is nonsense, according to mine I should run >170PSI, I run 140/130 and that's hard.
If you're happy buggering about with forks internals I would take Bagstard up on his offer.
Really would recommend the Marz 55 RC3's. Best forks I've tried.
Bagstard Ill take you up on the offer, will PM you now as well as give all the above a go.
It would see less air is the key as the recommended amounts are too high, set sag too 25% in the "attack" position rather than just sitting on bike (which I am sure I did but will re check).
Give Bagstards damper a go and see how much of a difference that makes.
And report back.
if still po-go like, slow the rebound off too.
Let us know how you get on. #is about to buy a 160 fork 🙂 #
I think fix what you have, most of the high end forks are much of a muchness now.
I've ridden the 55RC3Ti's, had a set of 2012 Float's & a now some BOS Deville's. They all feel different, but I wouldn't say one is 'better' than the other.
When I changed the compression damper I was told to change the rebound one as well for mission control- the lower spec ones don't move enough oil for the compression damper to work properly
Just saw this highlighted- I'm at nearly 30% sag. You won't be doing yourself too many favours with that much air in the forks.
After having a discussion with Bagstard he has 09 U-turn mission control damper on offer. As i mentioned to him I don’t know if there are better than what I have currently or if there are even better out there.
It would certainly seem that I need to run more sag than what I have. I am now also not sure if its worth trying the new damper without changing the rebound as suggested.
I think the newer rebound is end of stroke biased and it sounds like you have newish forks. According to this your rebound is of the new design so don't worry about changing that. The compression cartridge you have in there sucks balls.
http://www.sram.com/rockshox/products/lyrik-rc#/path/term-id/7
I have High and Low compression and floodgate on my Lyriks and they are brilliant.
I don't know why people insist on hi and lo compression adjustments, hi and low rebound make much more of a difference to performance.
Dual flow rebound in my forks they seem to sort themselves out pretty well, although I have never tried separate H+L rebound adjustment.
I've never seen a for with H+L rebound (not saying they don't exist.)
Apologies if you know all about setup, if not, hope these pointers help.
My Lyirk Solo Air RC2DH is up there with all the other top performing forks I've ridden (everything from Boxxers, Dorados, Bombers, Shivers, Fox, Pikes, RLT Ti's!).
Other 160 options are 36's, DeVilles, Marzocchi but once they are all tuned right, the differences from one to another are not really huge.
Certainly in terms of chassis stiffness, spares and durability, I'd say the Lyrik is one of the best. The damping on the base models can need some work.
If you are changing dampers, you really need to make sure you have the dual flow rebound in there, makes a big difference over previous RS forks.
As you say, you could sell up and by a better fork but I'd check how much an RC2DH damper and dual flow rebound assembly is from TF or LoCo.
Initially though, try some setup tweaks - if these are heading in the right direction but not good enough, it might give you confidence to go for the damper upgrade, if not, you'll know what you want in a new fork.
Find a typical tough section and session over and over while playing (and noting) with settings.
Sag 25-50%.
Too much air looses small bump sensitivity and ramps up too fast on big hits. Drop the sag and see how they ride, if you are bottoming out, add 5psi at a time.
Compression - back right off so there's none and add a click or two at a time if the forks are diving too much.
Rebound - if the forks are pogoing, the rebound could be too fast. Set it 12 clicks out as default and tune from there. Go higher if you have more PSI,
If you go for new forks, dont over look the cheaper brands. I just bought some x-fusion vengeance and the build quality from the outside looks excellent! Tough paint, machined screw on cover to go over hi/lo compression adjust, seem very stiff. I've only just fitted them, so not had a chance to ride yet, but apparently the damping is very good, each click has a meaningful change, whereas all the fox+RS forks I've had in the past didnt do anything until the last few clicks.
Also worth bearing in mind, if you upgrade your existing forks, you are unlikely to get (much of) that money back on resale.
I have emailed Loco and will take all thepointers from here to the trails tomorrow and have a play.
My Solo air RC2DH's are sublime.
if you fit a standard mission control compression damper, ditch the floodgate lockout. It improves small-bump compliance and is what RS did as part of the DH damper, takes 5 minutes and is reversible. I had solo air lyriks which were brilliant, improved with the mod, but arent a patch on my 55RC3Tis which really [i]are[/i] sublime.
http://www.pinkbike.com/news/technical-tuesday-lyric-mod-2010.html
[i]My Solo air RC2DH's are sublime. [/i]
And mine! The best forks I've ever ridden and just do everything from XC mincing (where the low speed compression damping stops them bobbing about) to DH.
love 'em, get yours upgraded!
my deville's were great for a couple of weeks after they were setup by a knowledgeable mate, 3 weeks later and suddenly the sag and compression had gone, 2 weeks away getting fixed, had lyriks before, kinda regret not getting lyriks again
Update - I have decided to push the button and get both the compression and rebound damper for a RC2DH and fit it to my fork. A very kind member on the forum sent me a PM with details on where I can purchase both new and delivered to my door for £140.
Its worth a go at that money.
One last question I have is will fitting the above dampers still allow me to use the 2 step function of the fork?
I'm running my lyriks with 35% Sag. No way would 20% sag be of any use. It makes them way too hard and yes you get the wandery feeling.
I'd personally set them up with more sag and slightly speed up the rebound.
What I presume you dont like is the fact they go through quite a bit of travel and want the fork to sit high, hence the fact your using 20% Sag.
To be fair I'm sure Santa Cruz say you should be using 30% as a minimum on Nomads, I know on my Blur LT2 if i use les sag then the bike feels slightly more taught on the flats and hills but it reall;y eats into the small bump compliance and doesnt feel good at speed, skittish and no traction.
I have the 2 Step function on my forks and it never gets used. Running 160f/140r and never feel the need to drop down the front end but I do understand the nomad is a high front end anyway so that might benefit you when climbing.
Where abouts are you Warren as you might benefit from getting someone to have a look for you and giving some knowledge as you dont sound like you know how the changes are affecting your forks.
^^^ Many thanks for the reply, the confusion was more around Rockshox and their various options you have when choosing a fork. Fox in my eyes seem to have simplified the forks as you only get one maybe two options when picking a fork.
Having done some reading and speaking to Loco I now have a better understanding on what I need to do. My current fork is not very complicated as you can only adjust the speed/.rate at which the fork rebounds with one knob and then the force required to depress the fork with another knob and that is it.
Setting sag is easy as it’s written on the fork station so no need to get the tape out. You are right in thinking that I like the front end of the bike to sit up and coming from a fox fork having the lyrik run at 30% sag seemed too much but from comments 30% is about right.
I am out tonight on the trail so will give all the suggestions a go.
Huh, the AVY mod is 250-300 dollars? Why would you need to sell your forks? The Lyrik plus Avy is going to perform every bit as well as a BOS fork if not better due to the stiffer 35mm stanchions. You'd get 150 quid for the forks tops, so you'd save about 350 quid towards a new pair of forks by not going that route? To get an equivalent performing fork your going to have to spend 800-900 quid on a BOS/Marz/Kashima Fox fork.
I'm having to try really hard not to buy the avalanche cartridge at the moment.
Warren
Was the source of the upgrades a sneaky secret or one you can share? I'm wanting DH coils, but can't find any so considering getting Uturn Coil RC2Ls and swapping over internals.
Unk
That would be because the Coil RC2DH fork is no longer in production, only the Solo Air, DPA air, and U-Turn are in production.
I suspected as much. Good to know there's no point in scouring the internet any more then.
Was there any good reason for ceasing production or just how SRAM decided to go?
Are they [i]really[/i] stiffer, or is it just an assumption because the stantions are 1mm larger?The Lyrik plus Avy is going to perform every bit as well as a BOS fork if not better [b]due to the stiffer 35mm stanchions.[/b]
The main things putting me off Bos is lack of parts, service manual, and sketchy reports as to how r53 are on communications. their website is still proclaiming the arrival of devilles in 2010 - And saying I should reserve one now. I know much of the supply problem on parts is from the bos end but that's not very encouraging either. I have enough of that with owning formula brakes...
Anyone know how much they charge for a service?
Based on a few peoples experiences, some do feel the BOS forks are less stiff but a lot of people don't seem to notice when riding. Some people are more sensitive to it though.
The point I was trying to make is why spend another 500-600 quid more than the cartridge.... on a new pair of forks when you can keep the Lyrik chassis, with easily available spare parts and seals etc and purchase a user serviceable avalanche damper that uses parts most motorbike mechanics could source for you.
What's not to like?
Yet again, Mission Control Damper and forks setup properly and your Lyriks will be mega.
Or spend hundreds making them mega...but sure TFtuned or Loco would advise the best route....which would probably include goin coil anyway.
I've got Bos Devilles and have never felt that communication with R53 has been poor. In fact I'd say it's been excellent. A service costs £150 including postage, but the service interval is every 2 years. Oh yes, I really like the forks as well.
