As above, any suggestions?
Its to fit a reverb 🙁
Halfords?
Halford?
Borrow if anyone is local, but otherwise Halfords are a good for Sunday supplies
Poundland. It's 6&9 BTW
Halfords, or small combo spanner from a DIY shop
Screwfix. But you will probably end up buying a set a way , so might as well get Halfords pro stuff as it's very good
Cheap set from Toolstation that you will probably regret buying.
Or a set from Screwfix
Halfords Pro would be my choice.
Halfords pro ratchet spanners.. just because they are more fun to use
A car boot sale? Though you may need an imperial equivalent.
eBay
Do you have an bigger spanners you could shim down with coins?
where are you located OP?
If you're near Dorking you can borrow mine
Hammer and chisel.
Not got a local cash and carry? got some silverline ones for pennies the other day.
Thanks for the ideas and offer!
I'm in Nottingham so Dorking is a bit far;-)
Home base was my source
Internal routing was my nemesis
Thanks for that!
Gave me a good chuckle before I turn in! 😀
