Where to get 35mm B...
[Closed] Where to get 35mm Boxxer foam rings?
5 Users
need 4
Posted : 21/02/2013 7:57 pm
TFTuned and or LoCo should have them.
Posted : 21/02/2013 9:15 pm
Boxxers don't use foam rings - there's two seals, one outer dust seal, one inner oil seal.
Posted : 21/02/2013 9:17 pm
I'm guessing Rob knows they have no foam rings already.
It's a Mod some people do on Lyriks/35mm Boxxers (Older 32mm Boxxers also)- remove the black oil seal and replace with two 35mm foam rings each side - so 4 in total are required. Improves small bump compliance and reduces stiction although bit more lower servicing is required.
Posted : 21/02/2013 9:32 pm
zangolin - Member
I've learned something new. Interesting that. I stuck a set of Enduro Seals on mine, they seem to have had a similar effect, although the foam rings make sense.
Posted : 21/02/2013 10:24 pm
Exactly right Zangolin.
I had this done by TFT on my old U-Turn Lyriks around 3 years ago when the 35mm Boxxers were first released, I believe it was a mod for the race scene initially.
Posted : 21/02/2013 10:45 pm
Zangolin top work. Now where do I get em
Posted : 21/02/2013 10:59 pm
Don't know Rob - as konastoner says Loco/TFT/J-Tec would be the people to ask.
Posted : 21/02/2013 11:30 pm
TF certainly have them- they fitted some to my Lyriks. But they only seem to sell them as part of the low friction seal kit, which ain't cheap.
Posted : 21/02/2013 11:49 pm
TF Low-Friction Wiper Seal Kit 35mm = £22
[url= http://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-35mm-2010-Boxxer-Parts ]http://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-35mm-2010-Boxxer-Parts[/url]
Posted : 22/02/2013 12:08 am
Loco says no, £22 is a lot!! I know it includes wipers but cash is tight at the minute.
Anyone know where i can these from??
Posted : 23/02/2013 9:21 pm
