I've just had On-One cancel my order due to a some mess up at there end and them not actually having stock. They were Sid XX 120mm
Can't find any anywhere....must be white/tapered/15 or 20mm and reasonably priced. £400 max.
Still not quite up to 26" stocks...
They're showing the same fork in stock but the RCT3 model and in black not white. That would be my preference anyway personally.
CRC have Marzocchi Corsa SL's in stock in, they're 100mm but can be converted to 120.
well someone, ahem 😉 , might just be selling some 1 1/8" (i.e. not tapered, but the right headset will deal with that) 20mm / 120mm Rebas on eBay at the moment 😀
xfusion Slides at Freeborn?
Well as it would happen On-one have miraculously received some more forks and my order will now be filled.
Yes would have preferred the RCT3 but not in black.
@Stoner I saw yours but the steerer wasn't long enough unfortunately.
really? what are you fitting it too?
That's been in a 21" scandal with room to spare.
my current steerer is 220mm
I run an abmormal amount of spacers... 😳
