Anybody know of any place that has Shimano brake hose in stock. Currently swapping parts over to s new frame and the rear hose is annoyingly 150mm short.
The existing hose is marked up sm bh90 and has a silver bango fitted. The brakes are m8000 xt.
Thanks Stw you are my only hope
You could try Uberbike - they list a comprehensive stock of shimano compatible hoses and fittings..
https://www.uberbikecomponents.com/category/434/Hydraulic-Brake-Hose-Kits
This should fit, if yours is a 2 pot caliper you will need to use your existing banjo bolt
https://www.sjscycles.co.uk/brakes/black-shimano-zee-smbh90-rear-hydraulic-disc-brake-hose-1700mm/
Edit black out of stock
I bought from bikeparts.co.uk on 6th Jan for my xt brakes. They ship quickly with Royal Mail tracked delivery.
I used this and it's working great.
You get the ferrule and olive and the grips to help with fitting + threaded fitting. The banjo is already fitted on one end of the hose.
