As per title, I've seen in the Fox tech guides the use of hex-key head screwdrivers - these are fixed ends ie not changeable.
Anyone know who makes them/where to get them - I have tried searching but to no avail. It would be hex sizes from 1 to 3mm.
Posted : 05/11/2014 11:57 am
They're normally called hex drivers, if that helps your Googling.
Posted : 05/11/2014 11:58 am
You mean allen key head? They wear out depending on use so standard allen keys are better bet (good quality ones at £2 each).
Your local engineering supplier should be able to sort you out with either, don't get the cheap ones 😉
Posted : 05/11/2014 12:00 pm
Found them now - thanks
Posted : 05/11/2014 1:06 pm
