CRC always used to be my go-to store but not sure they're the best anymore.
Where do people buy things like cables?
Thanks
Chris
Bike shop just down the road.
I have found Wiggle good of late for cheap cables, pads and the like, tend to tag the odd cheap consumable onto my orders...
I had written them off as useless a few years ago but things change...
LBS. Even with their 3000% markup. Use them or lose them.
Bike shop, it's really easy.
LBS.
Singletrackbikes, and LBS
Bikeshop
Bikeshop.
Cables and end caps occasionally come from Halfords if I can't get to the lbs during the week.
Looks like I should go and make friends with my LBS!
For things like that, Woolyhatshop via ebay.
LBS's are for major disasters, not for cables etc.
Pads - disco brakes
Cables - LBS
As above really.
LBS for cables and bits, brake pads from ubercomponants.
cables, approx 20 at a time from eBay, usually jagwire ones
pads, its superstar usually for me.
I'll usually add a spare or two into some other order. Evans recently as I've been using up Tesco vouchers.
Wiggle's Lifeline stuff is good and cheap. Otherwise I go to Halfords. I would use an lbs but they're only open when I'm at work.
Disco brakes for all my pads .. eBay or decathlon if passing for cables ..
Considering I buy cables and pads about once every 6 months it's no hassle to pick them up in the LBS when I pop through for something
cables from Wilkinsons!
pads from ebay, best prices for sintered I've found.
I buy XTR cables and I buy them online from wherever is cheapest at the time - Wiggle, CRC, Merlin, whatever.... Pads from Uberbike or xcracer.com. I find the premium for the XTR stuff is worth it for durability, also have a few metres of the outer on hand because the kit doesn't always quite include enough bits of the right length.
I tend to buy a bloody big reel of outer cable at a time from where ever is cheap, Planet-X recently but that has varied. Same applies with inners, I just but a job lot.
Disk pads have been Superstar of late, rim pads have been Wiggle and PX. I did pick a batch up from the Fibrax stand at the Cycle Show last year so actually haven't bought any for a while.
I buy boxes of cables etc. It's annoying when I need one and the shops are shut, and even if they are open, it's a lot cheaper.
Haven't bought an inner cable since about 1998
Cable outer SP40 from CRC. Order 1m they send 2
Pads only the real deal whoever is the cheapest at the time
Thanks all
