Original 900 lumen version, too floody, want to make it more spot. Can i get a new reflector?
i dont think that there currently is a specific replacement 'spot' lens - there is a replacement lens (like for like) and a wider angle lens avalible (both on ebay) - to get a tighter beam i've experimented with cutting a small black plastic cone which sheilds the light into a spot, ziptieing it around the bezil.
This guy was mentioned when I asked about spare lenses previously:
http://www.mtbl.robs-x.com/page15/page21/rapidcart/index.html
The "Euro spot" on that page isn't a true spotlight, but is certainly less floody than the original reflector (check the beamshots). I bought the set, which was decent value, only took a few days from America, so I'd happily recommend.
You might find someone who bought the '1200 lumen' version with the smooth reflector - quite spotty - and wants a floodier light, who's prepared to swap reflectors - there was a thread on here a few weeks ago where someone had swapped out reflectors without any major issues I think.
I may well be up for a swap, have bought the 1200 and know it is more of a spot but have a joystick for my head so might want something with more flood. If you give me a week or so to give it a good try and get back to you 🙂 wat ya think?
will email you highland28, whats the 1200lumen one?
is it this one?
http://www.dealextreme.com/p/t6-smooth-crown-waterproof-xml-t6-3-mode-1200-lumen-white-led-bike-light-with-battery-pack-set-82507
or
as i may just buy one of them instead of swapping
Sorry, should have said, it is the latter of the two that I bought. Just let me know what you want to do.
has yours arrived? how does it compare to the old one beam wise?
It should arrive on Tuesday at the latest I hope. And unfortunately I have never used the older version so won't be able to compare.
