Where can I get 60B...
[Closed] Where can I get 60BCD chainring?
6 Users
As above, looking for some 60BCD chainrings.
They're for Mrs DP74's [URL= https://singletrackmag.com/forum/topic/new-trike-day/ ] Mountain Trike[/URL].
She's had a couple of outings on it and it's a bit under geared.
Looking to put slightly larger chainrings on the front to speed it up a bit.
Been and measured the BCD and it's 60mm.
Waiting for a reply from Mountain Trike to see what sizes they do, but thought I might be able to get them somewhere else - any suggestions?
Posted : 16/02/2019 9:42 pm
Not aware of anything that is 60 BCD. Could it be 58mm?
Posted : 16/02/2019 9:52 pm
Yeah could well be 58.
Posted : 16/02/2019 9:53 pm
What size are you after? Can't find anything bigger than 24t in 58bcd...
Posted : 16/02/2019 9:57 pm
Think they're both 22tfront & back.
Could try a 24 on the front and may be drop the back one down too.
Will get the chain off properly tomorrow and confirm teeth.
The other thing I was thinking was seeing if I could get an adapter made to go from 56 to 76 - would give a bigger range then. Will need to measure and see if it can be done.
Posted : 16/02/2019 10:42 pm
Heard back from Mountain Trike and it's a 58 BCD 4 bolt ring.
Max recommended size is 26t.
Anyone know where I can get some from?
Can find 5 bolt but not 4 bolt.
Posted : 18/02/2019 2:34 pm
Betd / Royce / Renthal might (?) be able to make you something.
There are some solid bmx rings that could be drilled with the 4 bolt pattern. Might also need a flick in a lathe to open out the centre hole and reduce tooth thickness (most are for 1/8" chains).
What is it like for tensioning the chains? For info a total change of 4 teeth = add or remove approx 1 full link. 2 teeth can be accommodated with a half link.
Posted : 18/02/2019 3:51 pm
Maybe tap-up Martyn Ashton, see what he's running and where he gets them from?
Posted : 18/02/2019 4:15 pm
Send me a PM if you want, we can make custom chainrings.
Posted : 18/02/2019 4:28 pm
Thanks all.
Mountain Trike can supply them with the additional chain links for less than I expected.
Chain tension I'd done with a spring loaded tensioner.
Thanks @kayla1 will see how this goes and might look at changing the back ones later so will keep it in mind.
Posted : 18/02/2019 6:38 pm
No probs 😀
edit- why don't the damn smileys work on here?
Posted : 19/02/2019 8:43 am
Middleburn did 58bcd rings as well so if you ever need any more please email me at paul@betd.co.uk and I will help you out.
Posted : 19/02/2019 12:52 pm
