I really want u-turn so I can run my trance x at 120 and 140mm but can't seem to find any old stock anywhere.
Anybody know if anywhere has any instock?
http://www.thebikefactory.co.uk/productdetails.asp?productid=61313
Edit get you LBS to call Fisher and see of there are any left there too.
Would people just recommend getting some pikes?
I have not been keeping up with fork technology. Does Rockshox not do travel-adjustable forks any more?!
Pikes were good IIRC.. aren't Sektors the new Pikes?
I thought Rockshox still did U-Turn flavours?? My Revs are adjustable but not on the trail, I'd defo consider U-Turn Sektors if my forks die on me.
I can only find dual travel ones.
I will try and pick up some pikes
I think I have a few 150mm uturn coils you can use to swap with the dp spring, drop us a mail with you weight and I can check tomorrow when back in work. 😀
Hi loco, hope your well. Do you mean I need to source some DP forks then you can swap them to u-turn for me?
Good cheers, or I can supply converted forks, drop me mail and I'll cover everything. 😀
Ok mate, wish I'd have just kept the ones you got me last time. Ill mail you now.
Mail to your info@loco address?
I've done it on the email form on your site mate.
Loco not sure if the email will have for through.
Should I use the old indo@ address?
YGM Mosey 😉
