They all seem to be Debonair models.
Even second-hand ones seem to be 99% Debonairs.
Anyone know of a retailer selling the [b]HV aircan[/b] model [b]RC3 [/b][b]Plus[/b]'?
After a 200x 57 one.
Any help appreciated guys. 🙂
My dad has one for sale.
PM me and I'll give him your number.
It's hardly been used, one or two rides maybe.
EDIT: Wait, its 2016x63.
Get the debonair one.
ypu can put bands in the negative chamber to
Reduce the volume.
I can sell you an unused debonair with a full complement of bands. 200x57 medium/medium tune.
Really need the HV one guys, even with the bands fitted a Debonair is too linear for the Jeffsy 29er.
Its why they specced it as standard on some of the models.
Fit loads of spacers in and bump the pressure up then?
The reviewers said that about the 2016 Nukeproof Mega, that the debonair can made it too wallowey - except that if you set it up right a bigger negative spring allows you to have more midstroke support.
FWIW you can convert a debonair to a normal can if you can find the parts. Have you considered an non-HV version? There's not a huge difference in the can and it might be easier to find.
Band in the negative chamber or positive?
Thanks for info guys.
I am really set on the HV really, though the Debonair can be converted at a cost.
Tried the Debonair all spacered up before on a bike that should have had a HV and it just didnt feel good.
My current weight of 15 stone no doubt doesn't help!
Will have to keep an eye out for a s/hand one from someone's upgrade or something. 🙂
I think I have a HV air can at spare from when I moved to a debonair. I'm away until Wednesday but will give you an email if I can find it!
OK bud, sounds interesting! From a 200x 57 Plus?
Cheers and let me know how you get on. Email in my profile bud. 😉
if you fill up the negative air chamber with a couple of bands that's the equivalent of a HV can. I take it this was the same bike as yours you tried with the DB aircan?
The other thing is the compression probably isn't set up great for a person of your weight either which is going to affect how it rides. What bike is it you have?
I have the Debonair on my Stumpy 29er and no matter what combination of spacers I add or subtract in the positive / negative chambers it's still shite. I have to put 340 psi in the shock to achieve 35% sag and it fidgets around mid travel never really bottoming out. Very Soft up to 40-50% travel and then becoming bloated. It's really for lighter riders with a low leverage frame design. I'm in the process of finding a standard air can from America which suits Specialized frames better. Ps... I'm 230lbs.
Double post
Monarch on my suppressor was shit -
Changed to coil and it's sooo much better don't think the damping on the shock is ipvto much
Double post
