When does a bike be...
[Closed] When does a bike become retro?
39 Users
I'm still riding an original on one tinbred which is now 8 years old and cannot see me replacing it anytime soon. So who else is riding a bike/frame over 5 years old and when do you consider a bike to be retro?
Posted : 23/12/2011 8:54 am
When it has non suspension adjusted geometry.
Posted : 23/12/2011 8:56 am
When MBR tell us.
Posted : 23/12/2011 8:57 am
when it can't run disks (for an MTB)?
when it has a horizontal top tube road? 😉
(edit: or is it [i]an[/i] horizontal top tube?)
When it becomes last years model or goes on sale
When it becomes last years material
When it's wheel size becomes no longer trendy niche
When you need to fit an Angleset
About 10-15 years ish according to retrobike
Posted : 23/12/2011 9:00 am
When its shit compared to a £500 specialized but you remember it being good.
Posted : 23/12/2011 9:03 am
When you buy one, thinking exactly this, and it happens to be waaaaaay better than you remember.
Retro = Just old
Classic = Old but actually very good
This is why old Konas have such a following.
Posted : 23/12/2011 9:12 am
When a stranger pays an interest in it on the trails/car park/outside the shops/pub, instead of ignoring your £3 grand new bike.
Posted : 23/12/2011 9:16 am
How about my mid 90s Raleigh special products titanium? takes discs, rides ok with a 100 mm fork, retro and classic
Posted : 23/12/2011 9:19 am
TJ, Yep, they are pretty sought after, and quite nice. They were nice at the time.
Is that the one with Ti tubes bonded into cro-mo lugs?
Posted : 23/12/2011 9:22 am
Nope - fully welded frame all TI - no lugs
Posted : 23/12/2011 9:23 am
Mid-90s with disc mounts? IIRC IS standard was only set at the end of 97 wasn't it? So that'd make it late 90s...
Posted : 23/12/2011 9:28 am
Modern rubbish. I have a bonded metal matrix Dyna-Tech (no discs, designed for a very short fork).
Posted : 23/12/2011 9:29 am
when it was designed to take a stem the same length as the top tube?
Posted : 23/12/2011 9:44 am
I've always thought we mis-used the term 'retro' a bit, we normally use it to describe 'old' or 'old-skool' (for the kids 😉 ) but it's actual meaning is something that [b]imitates[/b] a design/concept from the past, or [b]relating to[/b] the past, not necessarily being [b]from the past[/b], if that makes sense?
...but I digress, to answer your original query, there is a bit of a grey area amongst the retrobikers, some say pre-90's, some say pre-2000, but there seems to be an uncomfortable middle ground of about '97 that gets agreed upon depending who you ask.
For a lot of people its more about a shift in focus of the designs rather than a specific year cut off.
Posted : 23/12/2011 10:05 am
oh, and most of my bikes (frames anyway) are in the 10-15 year old bracket.
Posted : 23/12/2011 10:09 am
2006 Rock Lobster 853 here, but seeing as the current 2012 frame is exactly the same it's not retro !
I thought retrobike defined it as 1997.
Posted : 23/12/2011 10:21 am
I've got a 1995 Mongoose Amplifier full sus, one of the ones made my Amp Research. I think that one's a bit retro and classic.
Posted : 23/12/2011 10:27 am
Lols @ aracer
Posted : 23/12/2011 10:36 am
No idea
I ride a 2004 Specialized with modern forks, wide bars and a short stem, so it doesn't really feel "retro" to me.
Maybe the tag "retro" could be used to describe a bike which encompasses lots of perfectly adequate "standards" which have since been superseeded in the quest for ever more impressive marketing gnar?
Or maybe the "retro" tag could apply to any bike built before the term "colourway" was adopted by marketing newspeakers?
Posted : 23/12/2011 10:45 am
The "modern" forks on my Dyna-Tech are a 2003 model. I don't think some people on here really get "retro" - 5 years is a bit silly, given my main bike is almost that old, and there's really not much wrong with it. Fragile disposable carbon too.
Posted : 23/12/2011 10:51 am
Yeah, I'd still have my 2005 Schwinn, if some scrote hadn't come in to work and stolen it. That's not retro, it's cutting edge! 🙂
Posted : 23/12/2011 10:55 am
your riding buddies will let you know when !!
Posted : 23/12/2011 11:07 am
My newest bike is a 1999 Trek 6000. I also ride a '96 Bontrager Privateer and a 1993 Klein Fervour. I agree with the Retrobikes cut off of 1998, when v brakes became commonplace and 'modern' suspension design started to appear.
Posted : 23/12/2011 11:11 am
Anything no longer made, that makes you feel nostalgic and smile when you see one or ride it 😀
I would class TJs Ti Raleigh as retro, along with Super Vs and other stuff that era, on nostalgia feelings,
The MK 1 Purple Surly Pugsleys have already been classed as fat retro by the fat brigrade on MTBR despite only 6 years old 🙂
Posted : 23/12/2011 11:13 am
Retro is more of a mindset than an actual age. If your trying to keep the bike as it was when it was new, or to upgrade with age relevant parts then your definetely retro...
It's a fun rabbit hole to stick your head into; but I ultimately found riding round the handling issues and breaking old bike parts less rewarding than ragging modern bikes. Each to there own, I love looking at retrobikes and I still find many are more atractive than modern machines... but then I remember what they are like to ride *shudders*.
I've still got a 1994/5 Kona Explosif that I just can't kill.
Posted : 23/12/2011 11:15 am
Oh - mine has Vs (on the back - "modern" fork is disc only), but that's OK, as they're original XTs from '97 😉
On retrobike we split it in to 1997 and before / after 1998. Been lots of discussions on there and there's no specific reason for those dates except that there needs to be a split. Some think retro is before V's, others when most frames were still made of steel. Saracen were suss correcting frames around 1993 so that's no gauge and you could also get bikes with disc mounts around then (Mountain Cycles?) so that's out too.
Posted : 23/12/2011 11:17 am
I have a 2005 Cove Handjob & a 1989 MS Racing which has been converted to singlespeed.
I would agree agree with the '97 cut off generally as before this time bike design had remained quite static. At this point componentry made a step change and suspension became far more commonplace.
Posted : 23/12/2011 11:20 am
I’m still riding my '04 Enduro (on the rare occasions I actually get out and ride) and can't see me replacing it any time soon.
Posted : 23/12/2011 11:23 am
I have a 2003 SC Chameleon and I would definitely not consider that to be retro. Although the fact that it needs an adapter to run disc brakes does show its age a little. I would say 10-15 years, but then my bike would be about to fall into that category so I will have to say 15ish.
Posted : 23/12/2011 11:29 am
In some ways, I'd say that the easiest check is whether the frame will comfortably take a reasonable sized modern tyre - eg 2.2-2.3"
My '95 Kona definitely won't - at least, not without the tyre buzzing on the stays.
Posted : 23/12/2011 11:34 am
When middle age chaps on Retrobike will pay more than the new price for it!
Posted : 23/12/2011 11:35 am
This seems kind of relevant (stodge is an occasional poster on here)
http://www.stodgell.co.uk/?p=3406
Posted : 23/12/2011 11:38 am
 jimw
I guess my 10 year old Kitsuma ticks some boxes but not others- it is disk only, can take up to 120mm fork doesn't have a straight top tube but it can't take big tyres - 2.1 is OK but not much bigger and the design is eleven years old. Not retro as far as Retrobike is concerned, and not in the way it rides.
Posted : 23/12/2011 11:39 am
Not really - unless you consider that my '07 carbon susser is already retro.
Posted : 23/12/2011 11:40 am
i have a raleigh estelle racing road bike in my attic its about 20 year old...lol god its a heavy sod !!!!! the paintwork is amazing on it...prob get more for it if i had it weighed in...lol 😉
Posted : 23/12/2011 11:42 am
with bmx's as far as i can gather mid school =90's
old school = 1980's
for mountain bikes i'd say up to maybe 2000 are retro as a guess as bikes started getting disk brakes around this time generally.
or maybe - old school = cantis
mid school - v's only
Posted : 23/12/2011 11:51 am
Must resist 🙂
Posted : 23/12/2011 11:54 am
There are some good comments above but I tend to agree with this:
I've always thought we mis-used the term 'retro' a bit, we normally use it to describe 'old' or 'old-skool' (for the kids ) but it's actual meaning is something that imitates a design/concept from the past, or relating to the past, not necessarily being from the past, if that makes sense?
introduction of V's (and lack of canti's), steel being phased out, longer suspension capable frames, 9sp components taking on 'futuristic' appearances and losing charm of previous shimano etc groupo's, and generally better handling bikes are all calling cards of the end of the 'retro' days.
Posted : 23/12/2011 12:06 pm
I was going to post what amedias said too.
A bike that was made a long time ago is old. A modern bike, made with styling that harks back to old bikes is retro.
Posted : 23/12/2011 12:13 pm
Using the dictionary definition of course that's correct.
However, everyone most people know that "retro" in biking parlance means old, not a modern version of something older.
Posted : 23/12/2011 12:14 pm
I also find the distinction between 'old and crap' and 'retro awesometasticness' depends a lot on when the person making the distinction started riding...
You often find that people look back fondly on the bikes that were around when they started riding, the bikes you lusted after as a kid, or the bikes that the pros were using to push the sport forwards.
I'm sure in another few years people will be calling all sorts of things retro... hell, I heard someone call a mk1 Patriot a retro bike the other day! 😯
Posted : 23/12/2011 12:43 pm
indeed. my Cotic Soul will no doubt be retro when my son gets old enough to ride it!
Posted : 23/12/2011 12:45 pm
when another rider on the trails goes "blimey mate your brave riding that"
Happened a couple of weeks ago when I was on my 1991 trek. Although I think the splatter paint job alone firmly puts it in the 'retro' bracket
Posted : 23/12/2011 12:52 pm
It's defined by when you rode or dreamed of riding, or rather you'll probably end up defining it that way. RB is full of these threads and there's no definitive date. For me, its all the pre 95 stuff that floats my boat. Oh and an 89 Bontrager will run a 2.2 (not that I'd commit such heresy). It's all about the cnc!
Posted : 23/12/2011 12:57 pm
Must be a few on here.
I have a 1993 lugged/bonded Ti M-Trax, 21 speed LX, cantis, 1 1/8 threaded steerer, even a biopace granny ring!
Also have a 1999 Marin Attack Trail, JnTs, Hope C2s etc which I consider retro, and a similar age Coppi K14 with 9-speed DA which I don't consider retro, road bikes haven't really changed that much.
My 2004 SS Saracen has rigid forks and flat, narrow bar, I think of this as retro (as it rides like bikes used to ride) and yet it is still relatively modern, like what Mike said above.
Posted : 23/12/2011 12:58 pm
I think of Old-school / Retro ect as anything from the days of rigid forks, the first era of MTB design and riding. Up to 1990, maybe into early 90s. Anything mid-90s onwards is old, possibly classic, but suspension forks and category specialisation had come into it then, so original old-shool to me will always be from the first 5-7 years of MTBs being available in the mainstream - 1985-1990 ish?
Posted : 23/12/2011 1:03 pm
 mrmo
I guess that makes my two Bontys both retro, i even have a 1" black crown bonty special judy, complete with a englund air cartridge that took the travel to 70mm and saved a shed load of weight.
Just need to get round to sticking one back together, got the bits just have the frames in a cupboard.
Posted : 23/12/2011 1:19 pm
 Leku
Simple. 1" steerer.
Posted : 23/12/2011 1:20 pm
few other Bonty riders cropping up in this thread, thats nice to know 🙂
I may [i]only[/i] have a Privateer, but I still love it!
Posted : 23/12/2011 1:24 pm
8 years you say thats not retro the 2 in the pic are retro the pine mountain is in use at the moment and the owned since new 1988 Saracen tufftrax (recommended to me by Brant Richards) just needs a new crank and was in use uptill last year.
Posted : 23/12/2011 3:21 pm
That's a classic, surely? 🙂
Posted : 23/12/2011 3:57 pm
Simple. 1" steerer.
Nope. Not even close to correct. Most if not all Konas had oversize steerers from 91 onwards.
Go look at a 91 Kona, then compare it to any modern steel frame. They are all descended from that design, and are different only in minor details.
Posted : 23/12/2011 4:20 pm
Some interesting points made, just want to be clear I wasn't suggesting my tinbred was retro although it is in my opinion a classic
Posted : 23/12/2011 4:39 pm
I agree, but I think the Inbred in itself, not just the Tinbred, is a classic MTB, quite possibly THE classic British MTB of all time.
Posted : 23/12/2011 4:49 pm
I consider anything pre 96 retro (basically before I started riding). I have an early 90's Cannondale Beast of the East in the garage that I inherited from an uncle. When I first started riding this was the coolest bike ever (alongside a poloshed Zaskar with Judy DH's, Kooka Cranks and a Hope C2 on the front....)
My BOTE has Pace RC35's that barely move, an ATAC stem longer than my arm, USE bars and post, a Hope mechanical disc brake etc. With loads and loads of anodised purple! Oh, and a pair of Onza SPD's with elastomers instead of springs. It has a stupid sized steerer - 1 1/4 inch.
I never ride it, just keep it because I once thought is was very very cool.
I still get tempted when I'm on e-bay by old stuff that I loved when I first started riding; GT STS's, any Kona from '97, Super V's etc. I would snap up a Spooky Metalhead frame in no time at al, even if just to keep. That frame, along with the Z1 really changed things for those not fussed by XC riding.
Posted : 23/12/2011 6:20 pm
Best answer to what is retro would be to find where the next major jump in mass market bikes happened. If you work on bikes following the punctuated equilibrium school of evolution. I'd go for:
upto and including 1988 - early era mountain bikes
1989/90 - 97 - move to the 'modern' geometry, loss of thum shifters
1997 - V-brakes, front suspension as standard on most bikes, rise of discs, workable full sus for the masses.
14years on there has to have been some defining changes, poss not major ones in hardtails so it'll be a case of some becoming classics. Full sus its prob the point at which riding along and up stopped becoming a chore on a long travel bike? If 29ers take over the world then retro will prob become anything pre2012 or 2013.
Posted : 23/12/2011 6:39 pm
In that case my current road bike
Note Horizontal top tube
and my still used (less so now got a Specialized) mountain bike bought when I was 22. Am now 40)
Marcel
Posted : 23/12/2011 8:43 pm
