I've been toying with upgrading to push button shifting due to pain in my thumb joint (probably arthritis) with my ancient conventional setup (2x10) Can't justify north of £500 for SRAM and saw a 30% off deal for August orders on wheeltop EDS medium cage mech and shifters which brings them in at £280 Is there anything to be concerned about, it'll be going on an equally ancient On One carbon frame and used for pottering about on easy trails, no rock gardens or muddy stick strewn ruts. I'm in Spain so moisture ingress isn't an issue either. Any real world experiences out there? Thanks
There's a review in MBUK this month.
3/5 based on £410 RRP.
Easy to fit and set up, clutch a bit weak and jockeys didn't retain the chain well. Sram jockeys didn't cure it fully. Charging requires a proprietary cable as the battery is fixed. On one occasion it went weird and wouldn't shift past half way on the cassette but eventually fixed itself.
