Hi,
I'm looking for a new wheelset that would be for my Cotic Soul. I want them to be light, strong and easily serviceable by me.
I live in the Peaks and ride my bike everywhere - but I am definitely more into crossing mountains and big days out than smashing it down the hardest stuff i can find. They'll also be used for some mountain marathons later in the year.
Any suggestions?
Budget? Front axle type? Shimano MT35 are £80 A PAIR at on-one. You can use an adapter if your front isn't 15mm.
Default (bling) answer will be Hope Pro2 Evo hubs with Stans rims. Near £250
Hi,
Thanks fo post.
Budget? Medium? I haven't loads but am happy to spend if I know they'll last. I do believe 'buy cheap buy twice'is true for a lot of stuff.
Size. 26" and standard qr.
Stans rims of your choice on Hope hubs.
WTB rims of your choice on Hope hubs
Your choice of Spank rims built up on Hope Evos.
Oops, my price was a bit out on Hope wheels, £300+ seems to be the going rate.
[url= http://www.rushcycles.co.uk/m50b7s482p4881/HOPE-Hope-Hoops-Pair-Pro-2-Evo-Hubs-on-Stans-Arch-Ex-rims/RS_GB/11857 ]http://www.rushcycles.co.uk/m50b7s482p4881/HOPE-Hope-Hoops-Pair-Pro-2-Evo-Hubs-on-Stans-Arch-Ex-rims/RS_GB/11857[/url]
However, on 26" there are loads of second hand bargains, and you could likely get a good set for half that.
Interesting rocket man. I run WTB rims now and they have been pretty good. It's the stupid non-servicebale-by-me hub (they were off a Trek Ex8 and need a 'key' to service and i cannot get it from anywhere. Even an LBS i went to gave up on them one time) that irritates me and hence the new wheel's.
Can I just put Hope hubs on them then?
Nope - I'm being a plonker. WTB were off another bike.
I have Bontranger TLR wheels. Can I just put Hope hubs on these to get around hub problem?
What is it that you need? Bonty hubs are usually DT Swiss internals, there is a tool you need to do the centre bearing, this one:
No other special tools though.
You won't get a massive improvement going to Stan's/Hope wheel, seems ludicrous to spend £300 on a largely comparable set of wheels to avoid fixing what you have.
edenvalleyboyI have Bontranger TLR wheels. Can I just put Hope hubs on these to get around hub problem?
Mildly pointless re-lacing old rims on new hubs.
Double plonker -minds elsewhere. Bontranger Rythym Comp wheels. Can I put Hope Hubs on these? Cheers.
Njee20 - it's a tool to get a cap off to access bearings.
I see your point jimjam.
Hit with hammer 😕
Your bike rocketman?
Njee - that's why nonTrek LBS gave it back. Didn't want to hit with hammer..maybe I should take my balls out of my handbag and just get on with the hammer..
Good info re comparable wheels. Totally right - should solve access problem. Otherwise waste of money.
It's usually just a case of sticking something through, and tapping the end cap out. Alternatively, you should be able to use an axle vice to pull them out. I'd be finding a new LBS if that flummoxed them. I can't recall Rhythm Comps specifically, but they're unlikely to be anything different.
Unless you go for a decent upgrade I'd say so - DT240s on Light Bicycle carbon would be very nice, and light, probably c1300g, but more like £600.
I never went back to them (LBS) based on that. Although apart from the wheel issue I do nearly everything else myself anyway..
Merlin have good deals on Fulcrum wheels if anyone's looking at those.
Only just seen this but: I have a set of rhythm comps kicking about that I've taken apart before. IIRC the hubs are Formulas not DT. The back hub comes apart easily with cone spanners (20mm I think), bearings just tap out on the axle, although the freehub needs a daft imperial sized hex key (7/16"?). The front (mine is 9mm QR) has a notched lock ring that I think uses a tool a bit like a four-pronged freewheel tool, but I got it apart very easily with the first pin spanner I grabbed. If your LBS couldn't get them apart they need a bit of a kick up the bum, frankly, they're not trying very hard. 🙂
Give me a shout if you want any more info, my username at gmail dot com.
I have the WTB KOMi23 on Pro2Evo, still "new" to me, but seem fine. They now do an i25KOM for 2mm extra width. IIRC the KOMs are designed to [i]grip[/i] the tyre when dinged, if that helps!! I was hoping to desticker them, but the logos are non removeable - anyone have any ideas how to?
