Wheel lacing
[Closed] Wheel lacing
4 Users
Hi
I am trying to build a wheel set with some carbon rims. Never done this before.
So someone on here helped me do the spoke length. So I have two lengths should it be long drive side, or other way around?
Hope pro hubs if it's needed
Thanks in advance
Posted : 01/11/2013 9:44 pm
The person that helped probably used an online spoke calculator; the output from that will have stated which length goes on which side.
Posted : 01/11/2013 9:46 pm
If I were you I'd just get the longer length spokes. It will be fine
Posted : 01/11/2013 9:48 pm
Short on the drive. If it's your first attempt, maybe put a lick of masking tape around the rim (over the holes and pierce them) if you would hate to go and scratch your new rims.
If you aren't bothered about this.. fire away!
Thanks should that be the same for the front? Ie what size for the disk size
I have the spokes
Posted : 01/11/2013 9:52 pm
Shorter will be disc side on the front wheel
Posted : 01/11/2013 9:53 pm
This was my original thread
http://singletrackmag.com/forum/topic/wheel-build-help-for-a-dummie
It's awesome on here that people help, thanks
Posted : 01/11/2013 9:54 pm
