Wheel Help
[Closed] Wheel Help
5 Users
Hello.
I have a 27.5 2016 Giant Trance and looking to purchase a new front wheel, which seems to be a bit of a minefield.
The stock front wheel currently runs a 15mm thru axle at 100mm. I don’t seem to be able to find a front wheel within my price range which is up to approx £150.00 and fits the measurements of my axle, everything I find seems to either be boost or quick release.
I have been looking at the Halo vapour 650b Enduro / Trail wheel which fits the budget but I am unsure if the 100mm will come with a quick release instead of a thru axle.
Link to wheel here https://www.tredz.co.uk/.Halo-Vapour-27-5-650b-Enduro-Trail-Wheel_70653.htm?image=2.
Any advice if I can change a quick release wheel to a Thur Axle or any suggestions of wheels which would fit the bill would be much appreciated.
Thanks in advance.
Posted : 06/10/2020 7:38 am
Nukeproof Horizon front is right on budget : https://www.chainreactioncycles.com/mobile/nukeproof-horizon-v2-front-wheel/rp-prod195305
Neutron also available but currently out of stock: https://www.chainreactioncycles.com/mobile/nukeproof-neutron-v2-front-wheel/rp-prod195300
Posted : 06/10/2020 7:45 am
Probably better to ask tredz
Posted : 06/10/2020 7:48 am
Good find, thank you.
Posted : 06/10/2020 7:54 am
Seems to be cheaper on Tredz https://www.tredz.co.uk/.Nukeproof-Neutron-V2-Front-27-5-650B-MTB-Wheel_226674.htm
Posted : 06/10/2020 7:56 am
Same price, that link on Tredz is the 2nd link I posted and also out of stock.
Posted : 06/10/2020 9:25 am
Loads on ebay, what are you after in more detail, i.e. rim width (25, 30, 35?), tubeless or not, etc?
Posted : 06/10/2020 9:41 am
Anything wrong with your front hub?
You could just put a new rim on the current hubs? (Vapour is £50)
You might want the 28H version on the Trance... best to count.
Posted : 06/10/2020 9:46 am
Dhrider - yes you are correct.
Thanks all, I would rather Just replace the whole wheel to be honest.
I’m currently running 2.3 DHF & DHRs which I’m very happy with, so a wheel that will house these tyres.
I’m currently using tubes, I may or may switch to tubeless at some point I’m the future, but really not crucial for me (sounds like too much messing about for me, I like plug and play).
Posted : 06/10/2020 12:52 pm
