Wheel building help
[Closed] Wheel building help
7 Users
 RicB
I'm about to lace my first wheel. Front, hope pro2, Dt comp spokes, wtb 32 hole rim, 3 cross pattern.
Once I've laced the first and second set of spokes, can I just check that I rotate the hub [b]anticlockwise[/b] looking at the wheel from the [b]left[/b] side (i.e. rotor side).
Ta 🙂
Posted : 09/11/2009 2:01 pm
Anticlockwise looking at the drive side I think.
Posted : 09/11/2009 2:12 pm
 RicB
Ok. I thought it was the opposite to what you've said for a [b]disc[/b] wheel, because the wheel is laced to withstand the braking forces.
Posted : 09/11/2009 2:21 pm
 sv
3rd and 4th will go in the opposite to the first two sets anyhow. From memory - what Duggie said.
Posted : 09/11/2009 2:29 pm
Sounds like your making life difficult for yourself, completely lace one side at a time. Drop 8 spokes in one side (drive/disc) start with 3 spoke hole to the left of the valve hole, miss 3 etc. Now working from the same flange put the remaing ones in, from the opposite side, with the drive/disc side facing you twist the hub clockwise and lace the spokes over then under the two crossing spokes. Repeat for the complete side then flip over and lace the other side the same way. 😉
Posted : 09/11/2009 2:38 pm
Just buy Roger Mussons e-book. If you want to build your own wheels it's the best £9 you will ever spend.
[url= http://www.wheelpro.co.uk/wheelbuilding/book.php ]CLICKY[/url]
Posted : 09/11/2009 3:20 pm
Second the Roger Musson book. It's very clear and makes wheel building a doddle. Some good tips on making your own wheel building kit too.
Posted : 09/11/2009 3:38 pm
 RicB
Yes I guess at nine quid it's hard to justify NOT buying Rogers book! Will order it tonight
Posted : 09/11/2009 5:43 pm
Reading through this thread, almost seems like a contrived advert for Roger Musson's book. 😉
Having said that, looks pretty good might have to get myself a copy, cheers.
Posted : 09/11/2009 5:47 pm
