Wheel building
[Closed] Wheel building
9 Users
I've just finished building my first set of wheels and the initial ride, 200 yds up and down the street, didn't result in my agonising death in a hideous maelstrom of exploding spokes.
Should I take them for a pootle of a few miles then check them for rounditude and wobblicity, before giving them a proper hammering, or just go for it? How long before they are likely to settle down and stay true?
Posted : 02/07/2012 1:11 pm
Go for it I say*.
It took me 2 months to build my 1st pair - it turned out to be less fun than I expected, hence I wasn't too motivated.
I killed the rear one on ride number 5 in an ill-conceived drop to flat incident, got a rim swap at my LBS and it turns out my month wasn't totally wasted as at least mine was round! ****ing LSB effort is all bobbly!
Anyone know of a decent bike shop in S. Leics? I fear I'm gonna have to resort to building my own agen and I'm not looking forward to it.
*My advice not always reliable.
Posted : 02/07/2012 1:22 pm
My first set lasted 3 days of uplift before going properly out of shape. Re tensioned them with a tension guage and they've been perfect since.
Posted : 02/07/2012 1:23 pm
Rob - I'm in Melton and I'm pretty decent with wheel building if you're interested?
Posted : 02/07/2012 1:27 pm
Going for it this evening. I really enjoyed the process of building them and may have to invest in a tension gauge, but a best price of £45 seems a bit steep.
Posted : 02/07/2012 1:29 pm
my first 8 or 9 wheels were fine with only one needing minor adjustment after a massive whack.
the next set (first road wheels) went loose, really loose 10 miles from home, resulting me in a cafe with a spoke wrench putting my wheel back together & being given the name backwheel thom 🙄
i'd go for 5-10 miles and recheck if i were you.
whatever you do pack your spoke key. 😀
i would go for a local loop if the spokes are going to loose tension they will do it quite quickly [ not mine but a mates I was teaching the art ] ...more risk if you have alloy nipples as well IMHO
Just ride it and see
Posted : 02/07/2012 1:30 pm
schmiken - Member
Cheers schmiken, may well be in touch. Stuck this in my favourites for future use - currently ok as the bobbly wheel is on a frame I broke a couple of weeks ago in another ill-advised, unconnected, incident :mrgreen:
Posted : 02/07/2012 1:34 pm
If you're ever a bit further north, Mansfield area, give me a shout if you like & I'll happily check it over for you or build you one if it needs doing.
Posted : 02/07/2012 1:49 pm
Did it make any pinging noises on the first ride? If not, then hammer it. If it did, do a local loop then check.
Posted : 02/07/2012 2:02 pm
Posted : 02/07/2012 2:03 pm
check tension is even, and compare it with a known good wheel.
It seems evenly tensioned, and the same tension as my other wheels, using the "squeeze" test, and didn't ping on first riding. Pootling to the pub, 5 miles flat each way, with my missus this evening (spoke key in pocket).
Posted : 02/07/2012 2:07 pm
