wheel build help - ...
[Closed] wheel build help - flange diameter of Hope XC hubs
4 Users
Just found my rear wheel's rim is splitting so new rim and new set of spokes needed for a rebuild. Trying to work out spoke lengths. for the DT calulator here http://www.dtswiss.com/SpokesCalc/Calculator.aspx
I need to know
PCD and flange distances, and also diameter of spoke hole (why?)
hub is a Hope xc like this
http://www.hopetech.com/page.aspx?itemID=SPG165
rim I plan on is a Mavic XM319 like this http://www.chainreactioncycles.com/Models.aspx?ModelID=71060
spokes will be sapim race or DT comp in silver, with brass nipples, 36 of them laced 3 cross.
Okay so does anybody know the required info for the hub? Or where to find it? or how to measure it accurately enough on a hub that is still laced into a wheel?
now, gratuitous photo of the reason for the rebuild (one of several cracks)
I know the cause - spoke tension went out of whack and way too high after some desperate re-truing following a prang a couple of years ago....I'm amazed it has lasted for another 10k miles!
Posted : 12/02/2012 5:33 pm
Great! thanks. I'm coming out at 258mm both sides. Although neither the dt nor the mavic calculator has the xm319 listed 😕 so I've used the xm 719...hope that is the same/similar ERD!
Posted : 12/02/2012 7:51 pm
You are asking the dimensions of a hub that you have in your possession?
Do you have a rule?
Posted : 12/02/2012 8:17 pm
http://lenni.info/edd/
better spoke calculator as it has all the hubs and rims in its data base
Posted : 12/02/2012 8:19 pm
yes al, and yes, but it isn't all that easy to measure the pcd accurately...put a rule acros and the axle is in the way. similarly awkward with flange spacing, especially as the hub is still laced into a wheel. Conan's link was very helpfully just what I wanted.
al, you HAVE turned into elfin, and I claim my five pounds
Posted : 12/02/2012 8:41 pm
Ah now thanks 1111, that is really rather easy. It still doesn't have a xm319....I'm starting to wonder what that rim is that crc have....some OEM stuff perhaps?
Posted : 12/02/2012 8:45 pm
It's easy to measure both on any wheel, to the necessary level of accuracy.
Posted : 12/02/2012 8:58 pm
