What's wrong w...
[Closed] What's wrong with my Hilo?
7 Users
So, I fitted my Hilo yesterday, and inflated it to 25psi, but when I start riding it gradually sinks about 1-2 inches, also when I lower it, it will gradually rise up about 1 inch. It's definitely not cable tension as I loosened it until it was totally slack and the problems still persist.
So what's wrong with it STW?
Posted : 02/04/2012 7:40 am
Need to get hold of Foxyrider off of here, he has written [url=http://]up this maintenance procedure[/url] and seems to know the most about them. Mine had the opposite problem in that it was a bit stiff to lower, fixed by slackening the seat collar DOH!
When pressuring it, was it upside down with the lever depressed as that was what I did wrong first off. Mine is the remote version as well which seems to be very fussy about the angle of the cable run at the bars.
Posted : 02/04/2012 9:09 am
Yeah, Post was upside down with lever depressed, and it is the remote version, but I checked that the cable was slack at the top of the post. I'm thinking it may not have enough oil? or I'm just too heavy for it 🙁
Posted : 02/04/2012 9:16 am
Van Man, link not working would like to give mine a service any chance of a link?
Posted : 02/04/2012 9:34 am
I remember mine doing this while i was trying to get the pressure right.
IIRC, its due to slightly too much pressure, try letting 3-5psi out and see if that sorts it.
They seem to be VERY fussy about pressure, took me a long time to get it just right.
Posted : 02/04/2012 11:34 am
I would also fiddle with the pressures - also when you put a shock pump on it the volume @ 25psi is very small so when you take the pump off is often drops below 25psi when the excess is lost.
My article is here:
http://www.cyclistno1.co.uk/features/maintenance.htm
Posted : 02/04/2012 11:37 am
Apologies about posting a broken link 😳
I see its been provided by someone who knows what they are doing
Posted : 02/04/2012 11:42 am
I wouldn't go that far VanMan 😉 LOL
Posted : 02/04/2012 11:50 am
Thanks everyone, I'll try playing with the pressure and report back
Posted : 02/04/2012 12:04 pm
I've been faffing with my Hilo too and (in additiuon to Foxyrider's good stuff) found this [url= http://www.upgradebikes.co.uk/faq/xfusionhilo.html ]short FAQ on Upgrade's pages[/url]. The one interesting thing is the "lower the post, pull up the saddle, then depress the lever" trick, which does seem to have helped my post a bit after an oil change.
I too think I might have my pressure a bit high. It doesn't do the "gradual drop" but it does have a cm or so of springy sag going on - but only if I let it up quickly. If I feather the lever a bit when I raise it it's rock solid. Think I'll take a few psi out and see if a slower ascent helps things.
Posted : 02/04/2012 12:48 pm
Think I'll try the 'pull up the saddle' trick first 😀
Posted : 02/04/2012 1:38 pm
intresting stuff, I have the same issues on my Hilo. I think i didnt charge it upside down, will try that tonight
Posted : 02/04/2012 1:51 pm
Cheers Johnathan - Just updated my article with your upgrade link 🙂
Posted : 03/04/2012 7:13 am
