what's the shi...
[Closed] what's the shim for on a hope headset?
7 Users
Hello everybody,
I'm fitting a hope headset.
It has 3 shims and on the website it says optional up to 3.
What is a shim for and how many should I put in?
If anyone could help that would be great.
Thanks,
John
Posted : 10/02/2016 1:47 pm
The shim(s) go above the "wedge" shaped insert.
Basically, you want the rubber seal around the top cover to be on the headset cup - not so much it's dragging, but not leaving a space for water to get in either.
Posted : 10/02/2016 1:49 pm
I found it to be a classic case of a manufacturer going the extra mile to help and thus flummoxing me - a mechanical illiterate.
The idea is as scotroutes said - it is to fine tune the spacing so that the rubber seal acts as a seal with as little drag as possible.
The argument about whether you could feel the difference with the amount of leverage you are exerting via wide bars is a moot point for me.
Posted : 10/02/2016 1:59 pm
Yeah the tapered insert will sit at a slightly different height relative to the top cup on every steerer so the shims are there to get the top cup cover [i]just [/i]right
Posted : 10/02/2016 2:13 pm
I must admit, I just tend to use them all. At least that way I know where they are 🙂
Posted : 10/02/2016 2:15 pm
 lerk
Whereas I use none...
A smear of silicone grease under there and I cant feel any drag, yet the seal is as tight as a very tight thing!
Posted : 10/02/2016 3:02 pm
Yeah, you shouldn't need any- but they can help if the seal is deformed at all (ie squished in transit) or if there's any tolerance issues (which there won't be ime)
Posted : 10/02/2016 3:23 pm
