The 44t I have got on the turbo/ skip bike could do with being a bit bigger...
Or do you have to run a road bike on a turbo to get the most out of it?
TA do a 50t
Where have you looked for a bigger one?
try sjs cycles.
I think you can go up to 50 provided it doesn't hit your chainstay.
Just remember if you are running it single ring at the front you may have problems fitting a 50T with chainstay clearance.I know on mine I can only run a 44T largest.
Cynic-al - all the usual www. shops.
It will be going on an old 90,s steel MTB; skinny chainstays. Should be ok.
Simon - sorry if I am being thick - TA?
Cheers.
