Whats the go to 12 ...
[Closed] Whats the go to 12 speed chain?
8 Users
Just checked my GX 12 speed chain after about a year and its at about 0.75 worn so its time to replace. Its only done 800km but a lot of that will have been in slop.
So, is it worth spending a bit more on a xo1 chain or less on an NX chain? or is it much of a muchness? is there another brand 12 speed chain thats worth checking out?
Posted : 24/12/2019 12:03 pm
I'd just go with another GX
Posted : 24/12/2019 12:04 pm
Read an interesting article that basically concluded that the XO1 chain was cheaper per mile than the GX/NX ones. However, if you're racing, there is a 4W power loss over other chains die to the tight tolerances.
I like more expensive chains just for the corrosion resistance if nothing else.
Posted : 24/12/2019 12:53 pm
Where is this article? I keep blowing up GX chains.
Posted : 24/12/2019 12:57 pm
FYI, you're supposed to replace 11 and 12sp chains at 0.5 wear.
I didn't really believe the mechanic who told me, but it turns out its true and the newer Park chain checker now measures for it.
Posted : 24/12/2019 12:58 pm
Always replace ours with the X01s. Usually keep one spare and the keep an eye out for when any are on offer and try and find a voucher code.
Posted : 24/12/2019 1:05 pm
I have been running a KMC 12 speed chain and it’s been flawless, I have broken SRAM GX Eagle chains  with plates cracking.
Posted : 24/12/2019 1:06 pm
https://m.pinkbike.com/news/4-key-facts-from-the-cycling-tips-ultimate-chain-test.html?pbref=p
I started here, but went into a bit of a rabbit hole with it.
Posted : 24/12/2019 1:12 pm
I went down the rabbit hole to the Cycling Tips article.
https://cyclingtips.com/2019/12/the-best-bicycle-chain-durability-and-efficiency-tested/
Based on that for the OP - GX.
Interesting article though - all those that bang on about 9 sp (8sp, 7sp ad nauseam) being more durable - the chains most certainly aren't going by that testing.
Posted : 24/12/2019 2:01 pm
The other relevant question is how clean you keep your drivetrain.
Posted : 24/12/2019 3:17 pm
I’m good at keeping my bike clean, I have to keep it stored in the house.
Posted : 24/12/2019 4:05 pm
