Direct Mount Road or Standard Mount Road?
Its a praxis alba on a 2019 Spesh Diverge. The two above need different spacers according to instructions!
Worst game show idea ever.
You could call it Crankety Crank.
Whose Chainline Is It Anyway?
I should get my crankity crank cheque book out and go to a shop!!
In the hope of a proper answer it looks like this only dirtier!!
From what I see on their website, the Direct Mount is SRAM standard, so you should see 3 Torx bolts around the spindle. If you don't (like in the image above), then it's a fixed spider.
Thanks, so looks to be standard mount and needs a 2mm spacer.
Direct mount crank is about how the rings are mounted to the crank then? Like this:
https://praxiscycles.com/product/alba-m30/
It can be but in this case it's how the spider is attached using the same interface so you could fit a direct mount ring or a different spider
Direct mount then cheers, my googlefu is clearly weak!
You are the weakest link. Goodbye.
You are the weakest chain link. Goodbye
FTFY....
