What's it wort...
[Closed] What's it worth? / worth fixing?
3 Users
So, in a sleep deprived state of stupidness I decided to "have a go" at replacing the bearings on my Intense Tracer VP 2010. The bearings are absolutely knackered so inevitably the ones I've removed have come out in bits.
I've now decided that I don't have the tools nor skills to remove the remaining bearings and fit new ones.
The trusted lbs would charge about £120-£130 to do it for me, including parts.
What I'm trying to work out is - is it worth doing?! How much could I expect to get for the frame once it's had new bearings fitted?
Ta
Posted : 16/07/2016 1:25 pm
 cdoc
Nah, just throw it away. It's worthless.
On second thoughts, you could send it to me! I'll pay postage too!
Tbh, I would suggest that you have another go when you have had some kip. A cheap puller and a bodged together press are pretty easy to source and it is a far nicer frame than any I own.
Couldn't imagine letting it die for the sake of a bearing change even if its only worth a couple of hundred as is.
I know someone who picked a 2011 one for 400 in fairly good nick.
Posted : 16/07/2016 1:50 pm
Cdoc - I don't really have the time (mini RRR number 2 arrived 2 weeks ago hence the sleep deprivation!)
You don't fancy buying all or part of a 2010 intense tracer with XT groupset and Lyrik solo air rc2dh? The bearings may or may not need a little work 😀
Posted : 16/07/2016 1:54 pm
You may have just moved into the I've already started it hourly rate...
Posted : 16/07/2016 1:57 pm
 cdoc
The idea is very appealing, but I switched to hardtails only as my old mk1 tracer destroyed bearings like it was a design feature (well, that and it seemed to have rear wheel steering when pushed hard)!
I am sure that there will be plenty interested if you pop it on the classifieds, though.
Posted : 16/07/2016 2:02 pm
