What's in your...
[Closed] What's in your first aid kit?
33 Users
Doing some research, and came across this useful thread from 3 yrs ago. A little reminder perhaps?
[url= http://singletrackmag.com/forum/topic/first-aid-kit-contents-2 ]http://singletrackmag.com/forum/topic/first-aid-kit-contents-2[/url]
Posted : 20/04/2015 11:24 am
My what ?
Posted : 20/04/2015 11:26 am
Also worth looking at it occasionally, just checked mine and it had got wet so some things no use.
Posted : 20/04/2015 11:28 am
More pertinently, Where is your first aid kit? When I fell off, snapping off my elecronon and with it the end of my tricep tendon, and had an elbow squirting blood like a Monty python sketch, the kit was in the car :-/ so I ended up using a Jersey as a tourniquet for the 45 minute walk back...
Posted : 20/04/2015 11:29 am
My what ?
Same here... thought it time for some 'insurance'. Rudimentary knowledge, but no 'tools' for about 15 years worth of doing silly stuff on bikes.
Posted : 20/04/2015 11:30 am
I think they are largely useless.
Posted : 20/04/2015 11:31 am
Also useful if you need something to read whilst a mate bleeds to death
[url= https://itunes.apple.com/gb/app/first-aid-for-cyclists/id891259656 ]https://itunes.apple.com/gb/app/first-aid-for-cyclists/id891259656[/url]
Posted : 20/04/2015 11:32 am
Half a roll of clingfilm.
Posted : 20/04/2015 11:42 am
In 15 years + I've never carried one, nor had to use one.
Even for wounds as bad as CTM up there, a jersey was all that was really needed. Yes, a proper gauze would have been "right tool" for the job, but he's clearly not dead, so...
For stuff that's just inconvenient, small cuts etc, will stop bleeding eventually, and TBH MTFU a bit, for stuff that's life threatening, it's probably going to be beyond the scope of what you'd be able to carry, plus the most important bit of FA is not what you carry; it's knowing what to do.
One of these - a shell dressing. It comes in its own waterproof pouch.
Posted : 20/04/2015 11:45 am
Ok, noted - ta. This has been my view for the past 15 years too. Will sit tight and see if there's a compelling case for a different approach...
Posted : 20/04/2015 11:46 am
As Nickc says
Although I do carry a mobile and a emergency Bivvy bag
Anything else mtfu.
Edit - blurty what are you going to do with that?
Posted : 20/04/2015 11:47 am
Gaffa tape.
Posted : 20/04/2015 11:51 am
 Dave
[i]In 15 years + I've never carried one, nor had to use one.[/i]
In 15 years + I've carried one and had to use it. What are we trying to prove here?
As a minimum I'd carry one of these. I reckon that'll make the biggest difference between saving a life and dithering about...
Posted : 20/04/2015 11:53 am
We used an inner tube and a stick for a mate who'd destroyed his shoulder and snapped off the ball joint 🙂
Posted : 20/04/2015 11:55 am
I've only had to use mine a handful of times.
While doing the BHF South Downs 100, a guy came off and smashed his face in, blood everywhere and a good few cuts. Out of a group of 10 riders, I was the only one who could offer something from a first aid kit. I find it crazy that no one had one. You may never use it, but I'd always like to have it just in case.
Posted : 20/04/2015 11:57 am
Nothing. Just setting out to learn what's genuinely useful and what's not in the context of mountain biking.
Posted : 20/04/2015 12:01 pm
@FunkyDunk
I've never had to use it yet tbh.
I'd use it to cover an open wound/ open fracture. As a sling. As a tournequet
Posted : 20/04/2015 12:02 pm
Blurty - If they have an open fracture/wound, surely you would be dialing 999 pretty dam quick?
Have you been trained when to use a tournequet 😯
Posted : 20/04/2015 12:06 pm
Good point. Just checked mine... well, the part of my pack that was originally designated for first aid kits. It contains a triangular bandage, a field dressing, three nitryl gloves, one of which appears to have lost a finger, half of a twin mars bar with suspiciously greying edges, and a 9 speed powerlink. Just one. Oh, and a half dissolved Hi-5 tab.
Posted : 20/04/2015 12:14 pm
Pills - Antohistamine (some strong stuff and some non drowsy stuff) and paracetemol, Ibuprofen and some asprin.
Some bandages and plasters.
Eye wash which I've also used to rinse a cut.
sachet or two of suncream
Normally a couple of small bags of haribo but I might have raided those.
I've never used any of it on myself but its been used a few times.
MTFU is fine but why bother if you can make it as comfortable as possible?
Posted : 20/04/2015 12:24 pm
FunkyDunk.
I'd ring for Mountain rescue if I had a signal for sure.
Yes, I know how to use a tourniquet.
I'd use the dressing to lightly cover an open fracture - nothing more invasive.
Posted : 20/04/2015 1:25 pm
One of those pads you stick on a moderate to nasty cut and a bandage to hold it there. That's the only thing I thought would actually ever be useful that I could also competently use. Might pinch one of those CPR things from work too.
Posted : 20/04/2015 1:26 pm
Steristrips! I've saved wounds from needing proper stitches with steristrips on a couple of occasions. The 3M ones stick properly, the NHS ones don't.
Small scissors to cut clothing / bandages / plasters and aforementioned steristrips.
Clean wipes.
Painkillers.
Posted : 20/04/2015 2:03 pm
Ibrufen, Paracetamol, Tramadol, Antihistamines, some bandages, plasters, steritrips & foil blanket. I only carry this if it's a big ride with my ill prepared friends. 😉
Posted : 20/04/2015 2:07 pm
Go on then enlighten us.
Here is a useful bit of advice: http://www.southsnowdoniamountainrescueteam.co.uk/calling-for-help/ 112 and texting for the emergency services.
Posted : 20/04/2015 2:13 pm
 Nick
I could have done with something to cover this up, fortunately I only had a mile to ride home, mostly on road, would have been a real arse to have had to get down off the top of somewhere more remote.
[url= https://farm3.staticflickr.com/2917/13763166083_af4feed09c.jp g" target="_blank">https://farm3.staticflickr.com/2917/13763166083_af4feed09c.jp g"/> [/img][/url][url= https://flic.kr/p/mYcPLX ]2014-04-08 21.16.48[/url] by [url= https://www.flickr.com/people/10675959@N02/ ]nickgilling[/url], on Flickr
Posted : 20/04/2015 2:18 pm
A 1 ounce flask of absinth.
Posted : 20/04/2015 3:07 pm
How wise it is to give Tramadol to another rider? Genuine question - I thought it was prescription only and had various side effects associated. If you gave Tramadol, what would happen if the injured rider needed surgery, for instance? And if prescription only, what are the legal ramifications?
Posted : 20/04/2015 3:25 pm
Just like the ones I use at work then.
I take it you know how to close wounds?
Posted : 20/04/2015 3:35 pm
Insulation tape (makeshift bandage, strap fingers etc), an inner tube (makeshift sling), pick up sticks from the woods when needed (splint with masking tape) and cable ties (secure falling off bit's of body)
Nick - that looks tasty!
Posted : 20/04/2015 3:39 pm
 gazc
always carry a silver foil space blanket, bandage/something to mop up blood/make a tourniquet from & a whistle as a minimum. luckily haven't had a life threatening incident
so far i've had to stick a hole in my head together with gaffer tape, bandage up a hole in a mates hand and helped another mate down innerleithen with a huge gash in his thigh (& go back up for the bikes)
Posted : 20/04/2015 3:41 pm
It is only for me and one other guy who is also used to it and only for extreme emergency back pain. I would certainly not give it to anyone who has not had it before.
Posted : 20/04/2015 3:43 pm
 Sui
Currently just an FFD as up there, but a new one which holds on to itself - annoying really the old ones could be used as asherman seals. Also a tourniquet, though shiz really has to go wrong for that to come out.. steri wipes, plasters bandages and also some second skin stuff (liquid or spray) can be very handy as it's antiseptic.
Posted : 20/04/2015 3:50 pm
 mc
The last I looked in my 1st aid kit (that I rarely carry on the bike and usually resides in the car) various bandages, some micropore tape, scissors, and I think there may be a few plasters.
I do however always carry a spare jersey, and have quite a bit of gaffer tape wrapped around my pump.
Two key things I remember from my MBL and first aid instructors are, one, a mobile phone is the most important thing to carry. Getting help for serious injuries is far more important than treating them.
Two, the only wounds you're interested in dealing with on the trail, are ones where big holes or lots of blood are involved. Anything that a plaster or antiseptic wipe will cure, can wait until you're of the hill where you'll have far better facilities to clean and dress it properly.
And for breakages, get creative. A jersey/inner tube/vet wrap/gaffer tape is far more useful than a triangular bandage will ever be.
As for drugs, my first aid instructor recommended carrying some aspirin in case you have to deal with somebody having a suspected heart attack, and possibly some ibuprofen for more general use.
The key things are, you should only ever offer the drugs, as you shouldn't be telling people to take drugs, and if the person is likely to need surgery, they probably shouldn't be taking drugs. However if you're an hour or more away from help getting to you, some ibuprofen may help reduce pain a bit until some proper pain relief arrives. Just remember to tell the medics what they've taken.
Posted : 20/04/2015 4:01 pm
Carry a first aid kit - mostly stuff to stop bleeding and over the counter pain relief - notepad to record what they've had.
As above, steri strips, sterilising wipes, a pair of latex gloves, medical tape, gauze pads and a space blanket, in winter I carry a bivvi bag too.
Have been looking at those nylon shelters after a worrying incident with an injury and broken bike on the moors in freezing rain and high winds.
Posted : 20/04/2015 4:27 pm
I carry a small kit on all rides;
Antiseptic wipes
15x15 cm adhesive dressing
7.5x7.5 cm adhesive dressing
Duct tape
All wrapped in cling film and slipped into a tool bottle or rear pocket. Really just for the immediate treatment of road rash that might make continuing uncomfortable.
For off road I also carry iodine spray, more plasters and antiseptic bite cream in a proper kit in the rucksack.
Used both sets several times. Including on myself. The road kit is about the same size as a spare tube.
Posted : 20/04/2015 5:46 pm
[i]my first aid instructor recommended carrying some aspirin in case you have to deal with somebody having a suspected heart attack[/i]
How d'you know if they're allergic? What size dose are you going to give them? If they think they're having a heart attack but are still concious and breathing, TBH best bet is to make sure they're kept still, and dial 999, leave the drugs to the paramedics.
Posted : 20/04/2015 7:52 pm
Ask them?
Posted : 20/04/2015 7:54 pm
Blurty when would you use a tourniquet ?
Please don't use one on me unless I some how manage to amputate a limb and blood is splurting out
Posted : 20/04/2015 7:58 pm
I have a couple of kits -
Work one includes some 'comfort' stuff like plasters.
Our family one, a little less.
I also have a really basic one.
All have Duck Tape in all of them - great for sticking all sorts up when you need to. It is folded, not on roll.
All have rescuci aid.
All have big wound pad.
(that is it for basic kit)
I also have tick remover's in the bigger kits.
Posted : 20/04/2015 8:32 pm
Drac - Moderator
Ask them?
POSTED 35 MINUTES AGO
Lol! Spot the Para. Beat me to it, but thought the same. First aid threads on STW never fail to entertain. Disappointed that no one has bragged about their CAT tourniquet or their EZ-IO gun that they carry 'just in case' yet...
(Personally, Just MTFU, and adapt what I've got, if really needed. It rarely is...)
Posted : 20/04/2015 8:36 pm
Righteo - here's what I carry in my first aid kit for work:
Two rolls each of 1cm, 2cm, 4cm zinc oxide tape,
2 each EAB 1" and 2",
Electrical tape,
Gaffa tape,
Steristrips,
Wound glue,
Staple gun,
Plasters,
10 little vials of sterile water for cleaning cuts and grazes/ washing eyes out,
A pack of gauze,
A selection of dressings,
SAM splints in various sizes,
Airways of various sizes,
Chrichothyroidotomy kit,
A&E collar,
Spinal board and blocks, and spider straps,
Scoop stretcher,
Stethoscope,
O2 bottle and various masks,
AED.
Posted : 20/04/2015 8:56 pm
Show off. 😆
Posted : 20/04/2015 8:58 pm
Not bad for a Physio.
Posted : 20/04/2015 9:01 pm
@wanmankylung - no Ventouse of forceps? God help anyone who goes into tricky labour around you!
Posted : 20/04/2015 9:06 pm
Rugby is a dangerous game.
Only things that I haven't had to use this season are the Chrich kit and AED.
Posted : 20/04/2015 9:14 pm
My point is simple. Basic first aid kits supply dressings that are seldom large enough to cover a decent road rash. Hence I carry my own just in case. If it's a serious injury it will be 999. If it is a nasty graze and 30 miles to go, then a giant plaster might make the difference. I've sealed a pedal gash with duct tape too, but nothing worse.
Last week's little accident saw my road first aid kit remain firmly in the back pocket until they cut my jersey off in the CT scanner. 😉
Posted : 20/04/2015 9:16 pm
A Sterile dressing or two, and insulation tape to hold it on.
Nothing else stays on in rain.
Posted : 20/04/2015 9:18 pm
What difference is that then?
Posted : 20/04/2015 9:20 pm
It might placebo them down the hill?
Posted : 20/04/2015 9:24 pm
It covered the modesty of some impressively ripped shorts, actually. Not mine btw.
Posted : 20/04/2015 9:53 pm
 mlke
Dunno why folks are being snooty about first aid kits? They're quite handy for making minor injuries comfortable for multiday rides or possibly some long rides. Painkillers/antihistamines/plasters for grazes etc all make for an easier second day. For sure if you can see bone then probabl? you're farked but most accidents aren't like that
Posted : 20/04/2015 10:16 pm
Would honestly carry shots of morphine with me for downhill sessions if I had a supply. Nothing worse than waiting for an ambulance with broken bones.
I'm glad I've read this thread anyway, it's reminded me to put some bandages and plasters in my bag for more minor injuries
Posted : 20/04/2015 11:05 pm
Main thing for me is a tick twister, those things give me the fear.
I carry stuff for cleaning wounds, antiseptic wipes and the like. Much easier to pick grot out of a graze when it's fresh rather than after it's scabbed over and going green. MTFU is all well and good, but a Real Man would be equipped to dress his OH's wounds after she's had an off. (-:
Also in there is a few dressings, ibuprofen and paracetamol, and odds and sods that came with the kit that I've not bothered to remove. I should sort it out really.
Tubes, duct tape etc are in the tool kit, of course.
Posted : 20/04/2015 11:30 pm
