What's going on wit...
[Closed] What's going on with my hub?
3 Users
Slightly foxed by something with my DT 240 rear hub. Everything seems as it should be going forwards or freewheeling, but there is a lot of resistance when I try to backpedal. If I loosen off the axle a bit it's fine. Does it with cassette and chain off.
Can't see anything which might be causing it to bind where it shouldn't. End caps are seated properly.
Have I missed something obvious? Not encountered this one before.
Posted : 17/01/2021 4:56 pm
Have you had the freehub off recently?
Not DT, but with Hope hubs if you don't reseat the seal properly it has a similar effect.
Posted : 17/01/2021 5:18 pm
Not recently. Seems a bit out of the blue.
Posted : 17/01/2021 5:24 pm
Time to pull the cassette/driver body off, clean and regrease with DTS minty smelling grease.
Probably a failing freehub bearing, seized spacer or gummed seal but start with the simple star ratchet service.
Posted : 17/01/2021 5:46 pm
Did the star ratchet service just now and cleaned everything up, all seemed in good shape. Will check the freehub bearings.
Posted : 17/01/2021 5:51 pm
And...it was the outboard bearing. Five minute job to knock it out and replace it. All good now.
Never had a 240 bearing need replacing before, hence the confusion 🙂
Posted : 18/01/2021 4:47 pm
