Whats better for a ...
[Closed] Whats better for a single ring...
7 Users
A double or a triple crankset?
I'm thinking its a triple as the middle ring position will give the best chain line, or is the big ring on a double in the same position?
Posted : 08/12/2013 8:13 pm
the bcd of both is the same and they are in the same position as a triple just has two where a double has one.
It does not matter basically.
Posted : 08/12/2013 8:16 pm
6 of 1
Excellent, ta. 8)
Posted : 08/12/2013 8:18 pm
more rings
Posted : 08/12/2013 8:19 pm
The spiders on doubles usually look better as they're meant to be "exposed" as opposed to a triple, so I'd go for that unless you want to use a bash ring. Chainline can be adjusted (although there shouldn't be much difference anyway).
Posted : 08/12/2013 8:27 pm
from what I've read, some doubles don't like being used as a single, for certain tooth rings - e.g the spider on a SLX double won't run a 32t without some DIY, whereas the triple is fine.
Posted : 08/12/2013 8:35 pm
The BCD of the double and the triple is the same so why it would struggle?
My slx ran 32 fine on 9 speed
Posted : 08/12/2013 8:59 pm
Triple. Not all doubles are the same - XTR Race doubles are a unique 88mm BCD and the ring spacing isn't the same, likewise SRAM doubles which are 80/120mm. The rings are in between granny/middle and middle/outer. So you can either have the chain line a few mm further in or out.
That said... Does look neater because you can use the outer position the ring is in front of the spider.
Posted : 08/12/2013 9:03 pm
Nonsense
Posted : 08/12/2013 9:05 pm
