What'll happen...
[Closed] What'll happen? 150mm fork on a 140mm bike.
4 Users
Have a 2011 Stumpjumper FSR with which runs a 140mm fork (standard QR). I have managed to get a 15mm Bolt thru fork but in a 150mm flavour. I have read many discussions on BB height, HT angle etc etc but will I notice any difference in real life with the slightly altered geometry?
Posted : 23/12/2011 12:14 pm
You might but probably not - at least not after a few mins when you're used to it.
10mm travel should equate to about 6/7mm once sagged which is well within the variance you might find between different tyres/forks/headsets.
Posted : 23/12/2011 12:16 pm
Highly unlikely you'll notice much difference. If the extra 10mm is a warranty worry then you can chock down Fox / Rockshox air forks with spacers to suit your frame. Otherwise, ride with confidence.
You'll notice the extra stiffness in the fork before you notice the geometry.
Posted : 23/12/2011 12:23 pm
Depends on the make of fork as well as they can have different axle to crown lengths, for instance i believe Rockshox used to be slightly longer than fox.
Doubt you'll really notice much difference though apart from the axle being loads stiffer.
Posted : 23/12/2011 12:27 pm
Brill, the news I was hoping for!! Thankfully both are Fox RL's. Just didnt want to mess up what I'm used to. Cheers 🙂
Posted : 23/12/2011 12:30 pm
