I'm lost trying to work out if these are 2011 or 2012 Rebas, anyone know ?
[url= http://www.on-one.co.uk/i/q/FORSREBRL29-WHT-9-118/rockshox_reba_rl_dual_air_100mm_29er_fork_with_poplock___white_red___9mm_qr___1_1_8 ]http://www.on-one.co.uk/i/q/FORSREBRL29-WHT-9-118/rockshox_reba_rl_dual_air_100mm_29er_fork_with_poplock___white_red___9mm_qr___1_1_8[/url]
Cheers.
you did notice they show as "out of stock'? They will probably be back up again soon though....
yeh, I already have them-from onone last year, just need to ID as I'm servicing / changing some internals.
ta
anyone ?
2011 was the first year of RL RLT etc... designations. Before that they were Race, Team, SL etc... so as you bought them last year, they will be 2011 model.
Also, 2012 rebas are very different - use the SID lowers. Easy way to tell, look at the bottom of the legs, if they're hollow = 2012+
The 2011 ones had 'hollow' lowers as well - I have a set.
Easiest way to tell is the 2012 ones have sag measurements etched on the stanchions and a much wider crown to fit flush with integrated headsets. So those are 2012. 2012 ones are also a bit lighter.
GB
