What works readily ...
What works readily with Hope Tech4 clamps?
15 Users
6 Reactions
I have Tech4 brakes and i was wondering what dropper levers and adapters, and also shifters and adapters work well together?
I have ofter used separate bar clamps for shifter and dropper, but id like something integrated this time.
Thanks
Ian
Posted : 13/12/2022 10:00 pm
Bikeyoke twiggy works with the Hope sram adapter.
Posted : 13/12/2022 10:37 pm
Anything with the correct SRAM matchmaker clamp works, so all seam stuff, one up lever too.
Posted : 13/12/2022 10:44 pm
Thqts great, thanks you
Posted : 13/12/2022 10:59 pm
We've got OneUp levers, 11 speed XT & XTR and 12 speed XT shifters mounted in our garage.
Posted : 13/12/2022 11:11 pm
Currently doing the same on my Tech 4's
Sram matchmaker for the shifter ordered but Wolftooth currently dont make a mount for their dropper lever to fit the Tech 4 lever so ive had to order a band on mount for the wolftooth lever for now
Posted : 13/12/2022 11:15 pm
I've asked Wolftooth of their plans. Their response;
Thanks for reaching out. We do have plans for Tech 4 ShiftMounts and ReMote Conversion kits, but we do not have a timeline for this project yet. Let us know if you have any other questions.
Posted : 14/12/2022 8:15 pm
Bit of a thread resurrection.
Got Tech 4 levers - how do I mount the Hope dropper lever?
Which adapter do I need?
Thanks
Posted : 29/07/2024 3:19 pm
hope dropper lever fits direct to tech 4 levers, no adaptor required
Posted : 29/07/2024 3:21 pm
Wolf tooth lever firs a SRAM mount, so you just need Hope's Tech 4 left hand SRAM shifter mount, bolts directly to any of the three holes on the Wolf Tooth with the clamp removed
Posted : 29/07/2024 3:43 pm
whatyadoinsuckaFree Member
Not direct, it needs the Tech 4 SRAM Mount also, which isn't included
Posted : 29/07/2024 3:44 pm
Which mount do I need to fit my Fox lever to Tech 3's?
Posted : 29/07/2024 5:02 pm
ok, i was sure i read it was a direct fit..
wolf tooth pro has a direct fit adaptor included for the tech4 (unlike the tech3)
https://www.amazon.co.uk/Wolf-Tooth-Remote-Hope-Tech/dp/B0C3JMXKGD
It's kind of crap that it isn't, given the price.  It doesn't attach to anything out of the box, AFAIK
Posted : 29/07/2024 5:25 pm
chestrockwell
Which mount do I need to fit my Fox lever to Tech 3’s?
Fox has the same 2/3 mounting holes, uses the SRAM mount
So you need the tech 3 SRAM shifter mount (LEFT) - HBSP325LH
Posted : 29/07/2024 5:30 pm
Cheers!
Posted : 29/07/2024 9:45 pm
That Wolftooth above is the pro version. The older design needs adapters of some kind as does not fit SRAM mounts out of the box.
Posted : 30/07/2024 10:06 am
Right, the older one you can bodge to fit, but not as tidy, the bolt comes up from underneath
Posted : 30/07/2024 10:49 am
Does anyone using the matchmaker system for dropper lever with Hope brakes find that you don't get enough adjustment for lever position? I am trying to bring my dropper lever forward as I have small thumbs but it seems limited unless you want to run your brake lever at a really steep angle. Am I missing something?
Posted : 24/12/2024 3:42 pm
There's not a huge range of adjustment.
This is something Mrsstu struggled with.
The solution for her was to run a right side adaptor on the left.
This brings the lever a fair bit closer towards the grip.
We also put a left side adaptor on the right to bring the shifter in closer.
Posted : 24/12/2024 4:32 pm
Annoying that the adaptors are only in black.
Posted : 24/12/2024 5:30 pm
i'm upgrading to tech 4 levers, whats the dropper lever of choice this year, my current wolftooth (oldstyle) lever has an adaptor to fit tech3 direct.
i can buy either
  • buy a wolftooth band and have it seperate to the lever
  • wolftooth pro
  • or;  buy a one up / hope tech / other brand and an SRAM Adaptor ?
my good friend isnt getting on with his hope tech one, anyone else not rate it
Posted : 16/01/2025 2:37 pm
