What tyres for... G...
[Closed] What tyres for... GLASS
37 Users
My commute takes me straight through the university area, where the streets are paved with shards of glass from the night before, and as a result, I regularly suffer punctures, especially to my rear tyre.
I have a rotation of tubes at home, but all are now patched and - I think - less trustworthy for it.
Is there a 700mm tyre out there that can save me the grief of getting up every morning ready to ride to work, only to have to abandon the idea for the car?
Or can STW proffer another solution? Anyone else suffer the same problem?
Posted : 27/01/2015 10:32 am
Fill your tubes with Stan's or similar.
Posted : 27/01/2015 10:33 am
http://www.schwalbe.com/gb/unplattbar.html
Posted : 27/01/2015 10:34 am
schwalbe marathon plus + thicker inner tubes = no punctures in 5000 miles
Posted : 27/01/2015 10:35 am
Marathon Plus will deal with a surprising amount of glass.
Change your route.
Continental Sport Contacts deal with the cycle path through Blacon in Chester OK. Glass can be a bit of a problem there, particularly in the summer.
Posted : 27/01/2015 10:38 am
I've had 3 glass punctures on my last 3 commutes! Each one was a different route as well. I'm going to check out the marathons.
Posted : 27/01/2015 10:42 am
Marathons and Marathons pluses are the sorts of tyres you fit and are amazed by.
I got my first puncture in the rear tyre approximately 2.5 years of commuting after it was fitted and in the tyres defence it was long overdue replacement.
I tend not to ride through roads of glass fragments, but for normal use they are simply excellent.
Posted : 27/01/2015 10:43 am
Marathon Pluses are truly excellent (if a pain to get on and off). I've never known anyone puncture one.
Posted : 27/01/2015 10:46 am
I've pulled chunks of glass out of Ultra Gatorskins before with out any deflation - for another option.
Plus, if its an adopted street and the responsibility of the council, call them and report the glass...
Posted : 27/01/2015 10:48 am
I've been using this:
http://www.wiggle.co.uk/panaracer-flataway-tyre-liner/
inside these
http://www.amazon.co.uk/Schwalbe-Road-Plus-Tyre-PunctureGuard/dp/B007XRCE9I
My commute is full of glass as well 🙁
How much better are Marathon Plus than Marathon Racers?
I have the Racers on my Commuter and have had punctures from flint embedded in the tread. Sadly, the cycle-way from home to work is awash with such stones.
Cheers,
Paul
Posted : 27/01/2015 10:53 am
The Pluses are noticeably more puncture resistant than the other Marathons. Weigh a lot more, though.
Posted : 27/01/2015 10:57 am
Durano Plus. Fast rolling, massive puncture protection.
Posted : 27/01/2015 11:07 am
Marathon Supremes here, very good.
Edit: And half the weight of the Plus if that's your thang.
Posted : 27/01/2015 11:24 am
Had the same problem. Marathon plus. Nothing beats them.
Posted : 27/01/2015 12:02 pm
yes new house = new commute.
pasela, marathon racer, durano, no good. marathon plus, are working for me so far (over a year)
Posted : 27/01/2015 12:28 pm
my commute takes me through 'the manor', it looks like this:
(and that's on a quiet night)
i've had no punctures in 3 years with a standard marathon on the front, and a 'plus' on the rear.
Posted : 27/01/2015 12:35 pm
+1 for flat away
Posted : 27/01/2015 12:39 pm
Marathon plus, for the silky smooth buckfast bottle paved streets of Glasgow, nothing comes close.
Posted : 27/01/2015 12:53 pm
Marathon Supremes here too, not had puncture for over a year and I go past 'the manor' nearly every day.
Posted : 27/01/2015 12:54 pm
Armadillos saw me through the bucky glass strewn streets of glasgow.
Posted : 27/01/2015 12:57 pm
Some people run Marathon Plus tubeless. That would probably deal with anything bar a nuclear strike.
Posted : 27/01/2015 1:10 pm
Marathon plus - never punctured one. I also rate Durano Plus if you actually want to go reasonably fast. Inner tubes filed with stans or tubeless.
Posted : 27/01/2015 1:17 pm
Posted : 27/01/2015 1:19 pm
In my experience no tyre will protect you fully against glass punctures. Some will be more resistant than others but eventually the shards of glass will work their way in.
You can help yourself though. Every evening I turn my bike upsidedown and slowly rotate the tyres inspecting them for embedded shards of glass and dig them out with a pointed knife. I'm not saying I don't get punctures any more but probably had about 2 or 3 last year doing around 4500 commuting miles.
Posted : 27/01/2015 1:20 pm
I've run Marathon Plus tyres for yonks (14 years plus?).
Only one puncture in that time - a 6" nail that ripped off the mudguard and would have stopped a bus.
You have to keep them pumped up hard though - and not rely on the thumb test. Rubber perishes after a few years. They are a pain to fit, but then I also run a hub-gear and coaster brake to make a tyre change even faffier.
Wouldn't run anything else on a commuter.
Posted : 27/01/2015 1:32 pm
Surely specialized armadillo has to take this.
Posted : 27/01/2015 1:34 pm
 benw
Use a cheap tubular tyre as an innertube and put some sealant in it and use it in combination with the tyres recommended above.Robert Millar used to do it apparently
Posted : 27/01/2015 3:06 pm
 kcr
Marathon Plus is the most bomb-proof tyre I've used in 20 years of commuting.
I'm always a bit confused by the different variants, and interested in people's experience of some of the other versions. My priority for commuting is reliability, but I would be interested in some of the lighter versions if there's not too much of a trade off.
Posted : 27/01/2015 4:40 pm
+1 for Conti 4Seasons/Ultragators. That double vectran layer does the job. I live at the wrong end of Hackney so glass a plenty. Only punctures have been a snakebite and strip of sheet metal both on the canal...
Posted : 27/01/2015 5:34 pm
4Seasons don't even come close to a Marathon Plus.
Posted : 27/01/2015 5:36 pm
 tomd
Marathon plus for sure. The only tyre broken glass fears.
I had good results with a set of specialized commuting tyres also.
Posted : 27/01/2015 6:23 pm
Marathon plus. end of.
I used to live in Clovenstone in Edinburgh where the local sport of smashing anything glass is activly encouraged, The Conti Gatorskins i used punctured tons (all within a 5m radius of the front gate) I reckon the Marathons could be ridden over a bed of nails.
Posted : 27/01/2015 7:05 pm
The Marathons are good, I have had good results with Michelin Pilot Sport 26" tyres. They are lighter with more grip and cheaper too. I think there are 700c versions in 28 and 35 flavours.
Posted : 27/01/2015 7:43 pm
Marathon plus with green guard, never had a picture with them, make sure you have some good tyre levers though.
Posted : 27/01/2015 7:48 pm
+1 marathon plus. The only puncture I've had with them was a nail. They are heavy but bombproof - ideal for winter.
I use sport contacts in summer when I can generally see the glass coming, but the puncture resistance is futile in comparison - I regularly get punctures with them.
Posted : 27/01/2015 7:53 pm
I tried stans in tubes and when I hit some glass, 85 psi of escaping howling air made a Catherine wheel of sealant, which covered me, the bike, the path and anything within a 15 yrd distance until it was flat. Then I had sealant pooled in the tyre and was a right mess. Bought some schwalbe belted tyres with normal tubes and will accept punctures, although commuted for 7 years with one puncture, but the retards smashing glass has caused 5 punctures this month so far, 2 new tyres and 2 new tubes. Tossers......
Posted : 27/01/2015 7:59 pm
Uncanny. Just started cycling into Sheffield. I've had 3 punctures in 6 days so this lunch time I've ordered some marathon plus tyres.
Posted : 27/01/2015 8:46 pm
